Can you make heads or tails of this?
#91
RE: Can you make heads or tails of this?
Getting back to the original topic as the poster above asked is there anybody that can furnish a pic of the connector that goes into the back of the nav that the two wires from the Onstar module connect into? I would like to know exactly what position the pins 4 & 5 are (where the two wires from the Onstar are inserted into the factory connector) looking directly at the connector when it has been removed from the radio?
Thanks for any help with this, getting ready to install the radio when all the parts arrive.
#92
ORIGINAL: genestoy
On C4 brown connector you guys use only pins_5_6_7_
the rest of the wires are for Denalis and Escalades
#94
gmgeek,
After my navigation upgrade and hooking up the onstar harness and wiring for voice commands I now have a humming or buzzing/whistling sound when accelerating. Someone else recently told me theirs did this also. JP told me this was common and they all do it. Can you confirm this is common? Is there a fix? It isnt that loud, almost sounds like a quiet supercharger or throttle body spacer whistling!
P.S. I will let you know on the camera, try to sell mine first! Thanks.
#95
ORIGINAL: biglg
gmgeek,
gmgeek,
also all those wires have to be twisted. that's what many manufacturers do in order to eliminate noise
#96
I am trying to remember. TMW could probably help me out more. I am thinking the JPcustoms connector they sent me was brown (maybe white), and went in the back of the onstar box. I seem to remember it only having ONE wire? Could this be right? I also got a connector for the c4 location the back of the HU. I cant remember now! Can anyone tell me what I have, LMAO. I am 90% sure that I only have one wire coming out of the connector I added to the back of the onstar.
#97
connector for the on star should have 3 wire twist. 2 of them go to your C1 connector behined Your radio, and third one is blunt cut, and they should be all taped
#98
ORIGINAL: biglg
#99
WELL SOB! Gmgeek, Can you hook me up with what I need to make this **** work right! What would you charge me to get me new connectors with the wires ready to go plug and play to make this simple for a rookie. Pisses me off that it is done, and now I have this damn noise and it is because of the wires used. GRRRR.
#100
ORIGINAL: biglg
