Can you make heads or tails of this?
Old January 10th, 2007, 10:18 AM
  #81
konasmrz's Avatar
Default RE: Can you make heads or tails of this?
LG,
Hole was not drilled. When you have the license lamp housing housing off (the assembly the chevy bowtie is mounted on that also has the rectangular mounting pad you see in the pic), you simply notch the edge of it - I did it with a pair of diagonal cutters - housing is plastic. Also, to your other question on the PM; after you stick on the camera bracket to the mounting pad on the housing, & using the double stick tape already on the bracket as supplied by Kenwood, I then drilled a single hole through the center of the camera bracket through the housing then inserted a 1/8" rivit for good measure as I did not trust the tape long term.
This is the easy part - wait until you try to fish that video cable connector through the hatch grommet by the housing and then the flex tube at the top - you'll be cussin' then! Remember my method - get a pair of long needle nose pliers & use them to expand the grommet large enough to push the connector through - that would be a lot easier if you get someone else to hold the pliers for you while you push the cable/connector through (I did not have that luxury.....)
Also, as I recall I had a couple of feet of video cable left that I had to coil with the routing I used.
Old January 10th, 2007, 3:37 PM
  #82
biglg's Avatar
Thanks for the reply. I figured out last night how to get the cable in, i see what you are talking about the notch! I will probably actually start on this project over the weekend. You make it sound like so much fun! I cant wait to get started!
Old January 10th, 2007, 4:13 PM
  #83
konasmrz's Avatar
When you finally get it working the satisfaction of having pulled it off is worth it.......
Old January 13th, 2007, 11:11 PM
  #84
biglg's Avatar
Well boys, all Igot to say that I got a Kenwood CCD-900 installed and working on the first shot! Thats right, who's da Man. I dare you guys to give it a shot! It was a damn good time today!
Old January 14th, 2007, 3:31 AM
  #85
biglg's Avatar
Here are some pictures. Sorry they arent the best. It is midnight, 10 degrees outside, and icing like a big dog! Over 1 inch of ice on everything!
[IMG]local://upfiles/3431/3FD46A209398400EBA8C5D651AC02428.jpg[/IMG]
[IMG]local://upfiles/3431/BCB1D54CCEC74739AFF559ADE5E2DDC6.jpg[/IMG]
[IMG]local://upfiles/3431/12795D7CAE394C609F997D404F607BEB.jpg[/IMG]
[IMG]local://upfiles/3431/02506E5D96174DD6ADB148E21452273F.jpg[/IMG]
[IMG]local://upfiles/3431/7D9C9E80766544269BBE3BD7A055CE6E.jpg[/IMG]
Old January 14th, 2007, 3:32 AM
  #86
biglg's Avatar
More!
[IMG]local://upfiles/3431/EF69AE7785ED4EA6A7FFE1628F4B2098.jpg[/IMG]
[IMG]local://upfiles/3431/44950CCA06D04B3EA136F6894BACF936.jpg[/IMG]
[IMG]local://upfiles/3431/9A3FA57E8A8F46B78775664643A9E864.jpg[/IMG]
[IMG]local://upfiles/3431/E3D3388BB80944F2B39592CDC5A4CE5C.jpg[/IMG]
[IMG]local://upfiles/3431/BF6FC4B66E934CEBA34F41C2C05F329D.jpg[/IMG]
Old January 14th, 2007, 2:27 PM
  #87
Did you consider painting it white? Might not be as obvious then.
Old January 14th, 2007, 3:39 PM
  #88
biglg's Avatar
I actually never thought about it. I dont know how that would have turned out. However, I can tell you I am not about to take it off so I can paint it.WAY to much work. Just in case you guys want to know, it isnt a very fun install and I dont recommend that most just jump in and try to install it. However, if I ever put one on another vehicle I think I will try and paint it! Thanks for the idea.
I guess it isnt as noticable as I thought, my wife finally looked at it today and thought it was fine and wasnt very noticable. So if it passed and received her approval, it must be ok!
Old February 16th, 2007, 1:27 AM
  #89
silverzz28's Avatar
Good info!
Old February 16th, 2007, 1:57 AM
  #90
silverzz28's Avatar
ORIGINAL: biglg
For everyone else I finally got my onstar wires going into 4 & 5 holes on the connector and everything works great. However I hear some whinning now through the speakers that is in sequence with the gas pedal. It isnt terrible, but it can be heard. ANy ideas?
Can you explain to us which wires you used on the back of the unit to make it work? I noticed you had a few issues at 1st
Quick Reply: Can you make heads or tails of this?
