Change my ignition cylinder now no crank no start
Old Aug 24, 2024 | 8:31 PM
TrevandGG's Avatar
Default Change my ignition cylinder now no crank no start
I changed my ignition cylinder on my 97 Chevy Tahoe because I have lost my keys as I got them replacing it and put everything back together the car started flying I was driving later that day my car stalled and would not start again when I turn the key the car makes no noise no clicking sound and it will not start also when I put the new ignition cylinder in my car stays in AC mode and will not go past it. I need answers and help so I can get my car back on the road so I can go to work I am confused as to why the car would not start and stays and the same like I said it makes no noise
Old Aug 25, 2024 | 6:21 AM
katewinslet's Avatar
Default Reply
Originally Posted by TrevandGG
I changed my ignition cylinder on my 97 Chevy Tahoe because I have lost my keys as I got them replacing it and put everything back together the car started flying I was driving later that day my car stalled and would not start again when I turn the key the car makes no noise no clicking sound and it will not start also when I put the new ignition cylinder in my car stays in AC mode and will not go past it. I need answers and help so I ehallpass can get my car back on the road so I can go to work I am confused as to why the car would not start and stays and the same like I said it makes no noise
The issue might be with the ignition switch connection or wiring. Double-check all connections and fuses related to the ignition system.
Old Aug 25, 2024 | 9:57 AM
Cusser's Avatar
If that was the only thing that was done, that would be the cause of your issues.
Mkiker2
Jul 10, 2024 8:39 AM
wis2ohio
Aug 12, 2013 9:46 AM
GGRtech
Jun 27, 2008 2:45 PM
joan
Sep 5, 2006 1:36 PM
