Clicking noise from the front left when turning right
Old Sep 8, 2015 | 3:21 PM
2004K2500's Avatar
Default Clicking noise from the front left when turning right
I have been chasing this issue for 18 months. When I turn right I get a clicking noise from the front left wheel/hub area. I have changed the half shaft and then the hub, nothing same noise. I have 100k on the vehicle at 2004 4WD 2500 Suburban with a 6.0L.
Old Sep 8, 2015 | 4:37 PM
Scotiapilot's Avatar
Hub bearings or your brake pads may be loose. Lift it up and shake in a horizontal fashion to see if there is any end play. But likely hub bearings second would be brake pads jiggling.
Old Sep 8, 2015 | 8:36 PM
2004K2500's Avatar
When I changed the hub the bearings were part of the replacement unit. I did try the end play, none. I will check the pads. The noise increases with intensity and frequency a the more I turn the wheel. if zero is straight and 40 degrees is full right the noise starts at about 15 degrees.
Old Sep 9, 2015 | 6:50 AM
SabrToothSqrl's Avatar
Default joints
I'd guess a u-joint or CV if that's the symptom.
Old Sep 9, 2015 | 7:15 AM
Have you tried rotating the tires to make sure its not a nail or screw that is making hard contact with the pavement when turning?
Just a thought...
Old Sep 10, 2015 | 1:25 PM
2004K2500's Avatar
when I replaced the half shaft the CV joints are included. I have pulled the tires and inspected them. I have been considering a suspension issue that maybe on the rack can find. Thanks for the replies, I think it is time to let a shop look at it.
Old Sep 10, 2015 | 4:40 PM
My bet.....im only gonna bet .02
Its your brake pads slapping around
Old Sep 15, 2015 | 11:51 PM
2004K2500's Avatar
well I fixed it. One of two things. Dust shield was slightly bent towards the rotor so I straightened it. Second lubed the caliper pins. Noise gone.
Old Sep 17, 2015 | 4:33 PM
Great news
tyer50
Dec 22, 2021 4:06 PM
KennyK1500
Sep 26, 2012 8:32 PM
litcatp
Jun 4, 2009 1:44 PM
jla74
Apr 7, 2009 8:08 PM
