coolant temp
Old Dec 16, 2022 | 12:28 AM
  #21
oilcanhenry's Avatar
Originally Posted by Skeeda
I just drive home from work about 30 minutes away. My top radiator hose got hotter than it was yesterday. My 2 heater hoses were both warmer than yesterday and my bottom radiator hose was a little warm but not cold like yesterday. But i also remembered that when I ran my ac it went to normal temp but when I cut it off it'll go back down to low temp
That was because the A/C system that cools the refrigerant down with the condenser, and heats up your radiator when the A/C is operational.
Old Dec 16, 2022 | 8:22 AM
  #22
Cusser's Avatar
Before i go to shop I'ma put a new water pump and gm thermostat in.
Can you replace the thermostat with the water pump in place? If so, maybe try that first.
I looked at gm thermostat and the one that's one here now and it's a big difference. The one I got in here now was holes at the bottom of thermostat and the gm don't and the top is way different than gm. Gm has a cone top and the other has a bubble type top
Can you post pictures of these? Might help us. Typically any weep hole in the thermostat faces up.
Old Dec 16, 2022 | 3:58 PM
  #23
Check the thermostat and see if it is fully closed when it's cold. It doesn't have to be open very far for the engine not to heat up in the winter time.
VanKo
Oct 5, 2020 6:49 PM
pacey
Sep 19, 2011 1:59 PM
MDTAHOE
Aug 24, 2011 8:12 PM
retsub
Feb 8, 2011 11:01 PM
Gyugyu
Uplander
Dec 14, 2009 6:13 PM
