cranks no start
Old Jun 21, 2014 | 2:00 PM
stoneface's Avatar
Default cranks no start
2004 suburban will not start, after reading different answers I changed the passlock sensor. It cranks but no start, did all the relearn stuff still no start. I removed the after market remote start. It tries to start but will not I can hear the fuel pump run when I turn the key. Could it be the lock cylinder? there are no dtc's It has fuel in the tank and a good charge on the battery.
any help would be great
Old Jun 21, 2014 | 8:03 PM
PreacherDJW's Avatar
I have a '99 suburban (229,000+ miles). About every 18 months to 2 years, I have to replace the rotor cap and rotor. Pull rotor cap off and chec the rotor and see if there is a crossfiring taking place.
Old Jun 22, 2014 | 2:35 PM
stoneface You need to verify fuel pressure, just hearing it spin up doesn't mean its working properly...
Old Jun 24, 2014 | 5:30 PM
stoneface's Avatar
I did a pressure test no pressure at the rail, going to check the fuel filter in the line next see if its bad.
Old Jun 24, 2014 | 7:00 PM
stoneface's Avatar
Well I was on another forum. One called Chevy suburban forum and read a topic that said when the tank is right at or under a 1/4 tank his suburban would not start as well as a lot of others mine was right a 1/4 I put 5 gallons in and it started right up. Go figure someone said there was a bulletin on this problem. Well it started and I guess I wont be letting it go below a 1/4 tank.
Another GM problem. I changed the passlock sensor for nothing 110.00 wasted.
Thanks for all the help
Old Jun 24, 2014 | 9:04 PM
Its most likely the fuel pump... the 1/4 tank plan may work for a while but the pump will fail....
kenehsr
Sep 5, 2010 5:08 PM
PrecisionAuto
Nov 24, 2008 11:42 AM
azpyroguy
Jun 18, 2008 9:32 PM
74chevy4life
Feb 14, 2008 10:13 AM
mike78olds
Sep 17, 2007 9:33 AM
