Extended warranties from aftermarket suppliers... Advice..
Old Oct 29, 2007 | 5:52 PM
  #11
MalibuMaxxSS's Avatar
Default RE: Extended warranties from aftermarket suppliers... Advice..
ORIGINAL: toydriver00
I did read it back to front. The only things not covered are stereo related components and for some reason seat heaters. Everything else is covered.When the bank was telling me about it I went into the "its too good to be true mode." I asked them to show me a contract. I read it, and I was impressed. The GM warranty sponsor for this site wanted $2200 for a 7yr 80,000 warranty. The dealer I purchased the truck from was even higher than that!! I paid $1575, and that included a 100% refund clause if the truck is totaled.
The totaled out clasue is basically a reimbursment for the extended warranty you wont be using now...GMPP can do the same thing, you get money back if you trade it before the time limit is up, as you are not using that much of the warranty now....and you can cancel it at any time and get some money back as well if you DID NOT USE it....
on a side note....try a couple of different dealerships, as a secret kinda with most extended warranties the dealer who sells it can mark it up how ever much they want, over what the warranty company sells it for, this is how they make some extra $$, as isthe case with interest rates as well, they are allowed to mark up .5 %...with that being sad THAT is supposed to change in the US then in Canada, I thnk it may already have in the US as I see GMPP quotes being givein over the net now, so you can not mark it up that way, however here the dealer can still mark it up a few hundred bucks if they want.
And toydriver does it specifically say brakes are covered, and plugs, I just dont beleive that....nobody covers that crap, these can go anytime its all driver dependent.....if your hard on brakes they can warp after 100 miles...
Old Oct 29, 2007 | 6:44 PM
  #12
toydriver00's Avatar
It is route66 warranty. It is only available through banks. Yes my contract specifically states everything is covered with exception of the items I listed above. Their site is www.route66warranty.com. Here are the details---I have the Easy Street program with NO Deductible.
Car Coverage
We have a choice of three different new car protections. Please read the descriptions to see which may benefit you the most. All plans come include Nationwide Service, 24/7 Emergency Road Service, and NO DEDUCTIBLE.
Click on the plan you would like to see the coverage for:[*]First Street - Drive train Coverage[*]Main Street - Deluxe Coverage[*]Easy Street - Factory (BEST) Coverage
First Street - Drive train Coverage:[*]Engine
Crankshaft & bearings, oil pump, pistons, rings, connecting rods & bearings, timing gears, chain/belt, camshaft, bearings, push rods, rocker arms/shaft, hydraulic lifters, intake and exhaust valves and springs. Engine blocks covered if mechanical failure was caused by the above-listed parts[*]Standard Transmission
Internal transmission parts consisting of gears, input and output shafts, bearings, overdrive housing and transmission case if malfunction was caused by the listed parts.[*]Automatic Transmission
Gears, input and output shafts, bearings, front pump, planetary assembly, sprags, governor assembly, valve body, torque convertor.[*]Drive Axle
2 Wheel Drive - Drive shaft, ring/pinion bearings, side carrier bearings, carrier assembly, thrust washers, axle, axle bearings, universal joints, CV joints*, & drive axle housing.
4 Wheel/All Wheel - drive shaft, differential, & CV joints*
* except if boot was damaged or missing[*]Cooling
Water pump - limited to 50% parts & labor[*]Electrical
Alternator and starter - limited to 50% parts and labor[*]24 Hour Emergency Road Service
Towing, flat-tire assistance, lock-out service, "jump-starting," fuel/fluid delivery, concierge service.
Main Street - Deluxe Coverage:
(INCLUDES ALL BENEFITS LISTED IN THE "FIRST STREET DRIVETRAIN COVERAGE" PLUS THE FOLLOWING)[*]Air Conditioning
Compressor, evaporator, accumulator and condenser, if factory installed.[*]Steering
Power steering pump, steering gear housing and its internal parts, rack and pinion assembly.[*]Brakes
Master cylinder, ABS master cylinder, vacuum booster, wheel cylinders, disc brake calipers, hydraulic lines and fittings.[*]Additional Cooling Coverage
Radiator, fan clutch, water pump, and cooling fan motor.[*]Fuel Delivery
Fuel pump, fuel tank, fuel injectors, metal fuel lines.[*]Front Suspension (for vehicles under 85,000 miles only)
Pitman Arm, Idler Arm, Upper/lower control arms, upper/lower ball joints, steering knuckle, wheel bearings, control arm shaft and bushing's.[*]Additional Electrical Coverage
Battery, voltage regulator, alternator, wiper motors, window motors, cooling fan motor, electric fuel pump, ignition module and coils, engine operation computer, distributor, starter, starter solenoid, seat motors, door lock actuators, manually operated switches for above listed parts.
Easy Street - Factory Type Coverage:
OUR MOST COMPREHENSIVE COVERAGE INCLUDES ALL LISTED BENEFITS IN THE MAIN STRET DELUXE, FIRST STREET DRIVETRAIN AND MOST MAJOR AND MINOR COMPONENTS. BASICALLY, EVERYTHING IS COVERED EXCEPT THOSE ITEMS SPECIFICALLY LISTED UNDER THE "WHAT IS NOT COVERED" SECTION IN THE SERVICE AGREEMENT.
For example, the small amount of parts not covered include oil, hoses, tires, cosmetic parts, glass, paint, etc. See the contract for the complete listing.
Additional Benefits of Easy Street Coverage are:[*]Rental Car Allowance[*]Towing[*]Flat Tire Assistance[*]Gasoline and Fuel Delivery[*]Lock-out Service
DerekShiekhi
Apr 7, 2015 12:30 PM
Chevrolet Forum News
Jun 4, 2014 6:08 PM
xjsken
Jul 29, 2013 7:37 AM
Freer-Love
Aug 5, 2010 7:33 AM
chevy2thabone413
Apr 28, 2008 2:10 PM
