Flickering interior lights
Old Mar 19, 2019 | 7:26 PM
David Carroll's Avatar
Default Flickering interior lights
08 Tahoe ltz flickering interior lights when vehicle is on what could be the cause
Old Mar 19, 2019 | 10:04 PM
Irish_alley's Avatar
I'm here for the party
did you add led lights?
Old Mar 20, 2019 | 7:07 AM
Just the regular lights
Old Mar 20, 2019 | 7:49 PM
exterior lights ok?
Old Mar 20, 2019 | 9:17 PM
Yes exterior lights are ok
Old Mar 21, 2019 | 10:18 AM
my 04 imp lights flicker also but i also notice the headlights will sometimes dim for a split second when i use another item that draws some current like the brakes. think its due to poor grounds not letting the alternator keep up. but haven't really messed with it
Old Mar 21, 2019 | 7:49 PM
could be
-charging system issue
if the flickering lights are all on the same circuit....I would investigate that circuit. if they are all power separately by the bcm...I would check to see if a tsb is present....maybe a programming update is available from the dealer.
Old Mar 22, 2019 | 7:41 AM
Alright I’ll check it out an see what happens
