front bearing hubs
Old May 20, 2009 | 2:16 PM
davidstereo's Avatar
Default front bearing hubs
Am i correct that the front hubs of my 03 burban are an easy pull off put onn fix? No bearings to pack just take bad ones off and replace with new ones?
Old May 20, 2009 | 2:37 PM
shawnvw's Avatar
Banned
You are correct.....a bit of a pain if you have 4WD as the CV Shaft likes to get really stuck in the hub
Old May 20, 2009 | 2:38 PM
yeah that's what i have u just hit it with a hammer correct?
Old May 20, 2009 | 5:31 PM
suzuki-guy's Avatar
When I did mine i had to heat the bolts up with a torch.
Old May 20, 2009 | 6:39 PM
mudmaniac's Avatar
Ride of the Month
May 2009
Use an impact wrench for the bolts and yes, just a tap with a hammer should do it.
Old May 20, 2009 | 6:41 PM
shawnvw's Avatar
Banned
This special tool helps a ton....
But if you don't have one, hammer and a punch will have to do.
Put the punch in vise grips so you don't smash your hand.
And don't hit the shaft directly with the hammer, you could damage the threads and end up changing the shaft
bfjones
Aug 16, 2019 7:37 PM
sct45
Apr 1, 2014 4:48 PM
Firefighter216
Jan 7, 2013 9:27 AM
hydrodriver
Apr 21, 2010 8:06 PM
texas patriot
Oct 17, 2007 1:07 AM
