Front end shakes ONLY when towing.
Old Jun 14, 2014 | 6:00 AM
Paulforpaws's Avatar
Unhappy Front end shakes ONLY when towing.
Hello all, new to the forum and Chevy Truck's. I bought a 99 Suburban LT, truck is rock solid, and clean. It's been to several front end specialist, some with 45 years experience. Truck's steering wheel and dashboard shake violently ONLY when towing. I tow, or I should say, try to tow a small jon boat trailer( Ventura), at 45mph the front ends starts to shake. It gets worse the faster I go. Shake lessens when speeds are 40mph and below. Ventura trailer is brand new. I also have another small homemade trailer that I was towing and thought that trailer was a problem but, it happens when I tow anything at all, no matter how light the tongue weight is.
I have a ghost! Please help.
Old Jun 14, 2014 | 11:25 PM
ROXTAR's Avatar
Only thing I could think of is death wobble. Which for other trucks needs an upgrade for the steering linkage
Old Mar 2, 2020 | 9:50 AM
Philippe Laurent's Avatar
Pauforpaws, did you find a solution to your issue? We have exactly the same symptoms on a ‘97 Suburban.
Old Mar 2, 2020 | 11:19 AM
shakes thru the steering wheel are front tire and steering linkage related. shake thru the dash can be rear tire, ujoint/driveshaft related. towing can change driveline angle so start with a ujoint check.
Old Mar 2, 2020 | 11:23 AM
Feedback much appreciated. We recently replaced the driveshaft due to abnormal wear, I’ll have the mechanic check the ujoint.
Old Mar 4, 2020 | 3:24 PM
repairman54's Avatar
4wd ? The front joints went on my old '99 Yuk before the rears to my surprise as not a heavy 4wd user.
suburbanfam
Sep 18, 2022 10:13 AM
Eaglecove1
Apr 10, 2016 7:31 PM
Iamlds02
Apr 6, 2015 12:06 PM
deryll1
Jun 11, 2013 9:52 AM
rcaw
Jul 19, 2010 4:25 PM
