FYI-Road noise and rattle in door
Old Sep 21, 2007 | 6:33 AM
TahoeG8R07's Avatar
Default FYI-Road noise and rattle in door
I recently took a trip down to Florida and was hearing a rattle that seemed to be coming from my door and unreasonable loud wind/road noise. I went to the dealer and had them check it out, apparently there is a bulletin about the weather stripping not sealing the door correctly. I'm not sure if this is going to correct my problem since they had to order the parts, but just in case anyone else is experiencing the same thing it's not normal and chevy is aware of it. I'll let you know if that fixes my problem.
Old Sep 26, 2007 | 6:53 AM
caddy's Avatar
Default RE: FYI-Road noise and rattle in door
One of the first things I noticed about my new Tahoe was the quietness of the cabin. I cannot tell the engine is running. Since this is my 1st post, I will have to familiarize myself with some of the threads to see the pros & cons of the vehicle, but after my wife owning a 94 Toyota 4-Runner since 97, I think I'll be more than happy with this Tahoe Purchase!
Good to be on board.
Old Sep 26, 2007 | 8:41 AM
davemec
Guest
Posts: n/a
ORIGINAL: TahoeG8R07
Have you had this fix done yet? If so, did it work? I have the wind noise and they've tried to fix it with no luck. Can you provide the bulletin number so that I can try giving it to the service department? Thanks.
Old Sep 26, 2007 | 9:02 AM
ZX1100F1's Avatar
PIT4172A Deals with wind noise or excessive gap between the front door and "A" pillar molding.
06-08-64-035C Addresses replacing the roof drip weatherstrip with a new softer seal weatherstrip.
99-08-64-016B Addresses the use of Dielectric Silicone Grease or the (even better) Goodwrench Weatherstrip Lubricant (Krytox) to eliminate squeaks.
Old Sep 26, 2007 | 9:47 AM
TahoeG8R07's Avatar
The service dept hasn't received the parts yet. After they do this, I'll give an update. Hopefully it is a good fix.
Old Sep 26, 2007 | 9:51 AM
davemec
Guest
Posts: n/a
Thanks for the info. I had the fix for the door gap done, but there still seems to be alot of wind noise on the dirvers side so I'll see if they can try the weatherstrip fix.
Old Sep 26, 2007 | 9:57 AM
davemec
Guest
Posts: n/a
Thanks.
Old Dec 3, 2007 | 8:47 AM
nflguy's Avatar
I bought a new 2007 tahoe LT3 in October. I'm hearing lots of wind noise on the driver side and some rattle/sqeek coming from a rear passenger door. I dropped of at dealer last week and they said the driver side wind was air rushing around the side mirror and they replaced the insulation in door panel on rear door but the hoise is still there, just not quite as loud. I'm gonna drop the tahoe off again today and hope they get it right. Driving down the freeway with the radio off makes me feel like the driver door isn't closed all the way.
JustinL
Aug 23, 2014 12:54 PM
JJ_DUDE
Feb 27, 2010 12:58 AM
e
Jul 29, 2008 11:25 AM
mrf
Aug 25, 2007 11:04 PM
73shark
Oct 27, 2006 10:08 PM
