Gas/Start up
Old Jul 31, 2014 | 3:23 PM
Batt1eRatt1e's Avatar
Default Gas/Start up
I've noticed something with my 2009 Suburban LTZ. Whenever I put gas in it and start it up, it kind of almost doesn't start up. Like it has problems starting up after gas has been put in. What could that be?
Old Jul 31, 2014 | 3:46 PM
markwemple's Avatar
Just a guess but, I'd think that something with emissions in the fuel return. I can't think of the proper term but there is a specific system that deals with the displacement of air by fuel that is now part of emissions that may be not working correctly.
Old Aug 1, 2014 | 10:16 AM
Official GM Rep
Hey Batt1eRatt1e,
We can check for any service announcements that may relate to this specific issue with your Suburban. Sorry for any trouble this has caused, but send us your VIN and mileage if we can further research this for you.
Amber N.
Chevrolet Customer Care
Old Aug 2, 2014 | 1:25 AM
Sammysue68's Avatar
Mine does the same thing! Let me know if you figure out what it is.
Old Aug 2, 2014 | 6:51 PM
if the purge solenoid doesn't seal, fumes from the tank will vent up the evap line into the throttle body. this creates a flood condition. locate the purge solenoid and remove the plastic fitting the runs to it. blow through the valve; you should not be able to blow through it. if you can, replace it.
or next time you refuel...disconnect the line at the purge solenoid. fill up. if the truck starts normally...replace part.
the evap monitor tests for leaks in the evap system. when this valve doesn't seal a dtc will set and the ses light will illuminate.
ahearnm
Mar 19, 2023 6:37 PM
ernestdelgado
May 31, 2011 4:24 PM
caddieb
May 15, 2011 5:32 PM
norrislaketn
Sep 22, 2009 10:19 AM
ourblackmad
Apr 29, 2008 1:35 PM
