Gearshift lever interlock
On my 99 Suburban, sometimes it will not come out of park. Truck starts OK, just the lever will not move like the interlock from the brake pedal (yes, I am pressing it down) is malfunctioning. I have ot mess with it a while and then the lever will move.
Is this a mechanical or electrical interlock? Any advice on how to check and/or disable it?
Thanks!
Thanks!
![Stick Out Tongue](https://chevroletforum.com/forum/images/smilies/tongue.gif)
You might try checking the connections to the stop lamp switch that is actuated by the pressing the brake peddle, as I believe this is what activates the lock release solenoid...
If you can easily get the switch out you might check out its operation to make sure its working before going for the solenoid as I think its a bit harder to get too...
It's not bad when the shift lever is on the floor but usually a major pain when it's on the steering column. The, ahem, "snick" noise will tell where the solenoid is located. The voltage to it comes through the PNP switch and then the stop lamp switch (or was it vice versa?). That's the reason for qualified "shift lever in PARK" and "step on the brake pedal."
Of course it will wait till you are in a hurry to not work..![Mad](https://chevroletforum.com/forum/images/smilies/mad.gif)
If it acts up again I would start with the switch attached (not really attached but activated by) the brake peddle...The contacts could be getting dirty or the plunger that activates it is getting dry and not sliding like it should and may need some light grease applied....
No response in a few days so it must be solved by now. One thought if not: sure sounds to me like the brake pedal limit switch (or whatever it's called). If the shift lever locks up again try checking to see if your brake lights light up when you press the brake pedal. If you get brake lights but the shift lever stays locked, your brake switch is likely good.
zee28
12
October 11th, 2011 10:32 PM
