GM Navigation Install Inquiry
Old Aug 12, 2009 | 1:40 PM
95z115's Avatar
Default GM Navigation Install Inquiry
We installed a OEM navigation unit into a 2007 Denali, GM navigation part number 25797978.
When the truck is parked, the screen stays on.
What could the problem be? Is it install error, or a bad Navigation unit?
Old Aug 12, 2009 | 4:21 PM
shawnvw's Avatar
Banned
please explain your problem a little better please.
Old Aug 12, 2009 | 8:54 PM
Is the key still in the Run position?
Old Aug 16, 2009 | 5:36 PM
95z115's Avatar
Negative, the key is not in the run position.
Shawn, the volume also does not work on the navigation unit or the steering wheel. It has been to 2 different dealers where programming was done. I dont know if it is a defective unit, bad programming, or bad install.
Old Aug 17, 2009 | 6:29 AM
shawnvw's Avatar
Banned
does your truck meet the criteria for a nav to be installed?
https://chevroletforum.com/forum/tahoe-suburban-25/how-install-oem-nav-2007-tahoe-2155/
Old Aug 17, 2009 | 9:11 AM
95z115's Avatar
I believe it does, a 2007 denali with bose, isnt that the only crucial requirement?
Old Aug 17, 2009 | 8:03 PM
shawnvw's Avatar
Banned
Sounds like it was improperly programmed
Old Aug 18, 2009 | 12:10 AM
95z115's Avatar
Yeah that is the vibe I get. I'll take it to another dealer and try again! Thanks for your help...
jpohl402
Jun 3, 2015 5:14 PM
Peragon
Mar 28, 2012 4:25 PM
asulaiti
Avalanche
Dec 17, 2011 5:34 PM
Sheri
10
May 1, 2011 7:23 PM
pat130
Jun 11, 2007 5:00 PM
