Old Aug 10, 2015, 1:59 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Lighting Guides
Print Wikipost
headlights come on, dash lights go out
Old Jul 3, 2020 | 6:03 PM
  #21
Steven Engle's Avatar
Originally Posted by tymr287
Just to be certain, make sure the dimmer switch for your dash lights isn't on the lowest setting first.
Yep. That was my issue. Adjusted dimmer switch to a higher setting and I could then see the dashboard, radio, and A/C panel lights in the daylight. THANK YOU!
Old Jan 4, 2021 | 7:00 PM
  #22
Shiznit54's Avatar
New User
Awaiting E-mail Confirmation
Default 2008 tahoe when auto or manual headlights come on the instrument lights go off
Found on my 2008 Tahoe the instrument lights on all the gauges aren't working when the auto headlights come on or manually turning headlights on. The problem is the driver's side sun visor is shorting out when you move it and causing dash lights to go off. So take and move visor back and forth towards windshield and dash lights will flicker on and off. You can remove visor and unplug connector until you can replace the visor to fix problem with dash lights.
Old Nov 5, 2021 | 5:20 PM
  #23
celtictodd's Avatar
The sun visor and dome lights were the issue. Disconnected both and now dash lights work fine with headlights on
gonz001
Feb 9, 2022 1:39 AM
badsled
Jan 29, 2021 8:22 AM
majorghn
Dec 26, 2018 6:49 PM
Rocker
Jun 21, 2013 8:58 AM
HarHam
Nov 10, 2006 10:15 AM
