2021 Suburban P2255 Code?
Old Nov 5, 2021 | 9:26 AM
Fraserjim's Avatar
Default 2021 Suburban P2255 Code?
Had all the lifters replaced. Some backfiring when lifter failed. I received vehicle back from dealer and just put my old OBDII scanner on it. Came up with a P2255 code which is supposed to be a bad O2 sensor. Dealer says that this code is not valid for a 21 Suburban.
Can anyone comment on this code and whether the backfiring might have damaged the O2 sensor?
Dealer does say there is a TSB covering weird codes due to chafing of a wiring harness near the engine?
Old Nov 6, 2021 | 7:21 AM
repairman54's Avatar
Since it's new I would let the dealer address the TSB issue. They have access to engineering's advise.
Mike2002GMCSIERRA
Apr 3, 2014 8:03 PM
62catalinagreg
Sep 19, 2013 2:00 PM
firemechanic
Jul 7, 2012 8:48 PM
expressvan00
Jan 13, 2012 1:49 PM
