Headlights/Fog lights
find the highbeam power wire at the headlight, splice into it using solder and heat shrink and hook it up to your foglights check the amp rating of the foglights and add that # to the amperage on your highbeam circuit and put in appropriate fuse with the correct amperage for both, but keep in mind that when the fog lights are on, the highbeams will be too, it works both ways so beef up the fog light fuse too
I didnt have fog lights on 97 Tahoe but I did use a relay to wire up my Hi and Lo beams so when the high beams were on the lows stayed on also...
I don't know if I would do that with the NBS as they generate a lot of heat but having the fogs on with the Hi's should'nt be an issue thou you might see some dimming when coming to a stop or at low engine RPM's
David_lee1993
November 1st, 2012 11:06 PM
samsonitus
September 15th, 2006 6:37 PM
mexican34
April 20th, 2006 2:26 AM
