Help! 09 tahoe stalls when fueling
My 09 tahoe will stall if I try to keep it running when fueling. If I shut it off and fuel it takes a min to crank back up but then runs great. Has new purge valve. I don’t know what’s going on.
Okay I’ll give it a try this evening and let you know how it goes. Wait do you mean the side that has the electrical connections? Take that side off and try fueling? Then start the truck with it off or put it back on? Do you think maybe the part from the part store is wrong one or maybe messed up from the store? Also when the truck is running and I take off the fuel cap it will stall
Pretty sure the vehicle has a Purge Valve and a Vent Valve..
To know just this is not enough. You need to know how and when they function and where they are located.
The location of some of them allows foreign matter to plug the filter plus if they are NORMALLY open or NORMALLY closed is essential to know
This might be best if you had a qualified shop with the info, capable scan tool and equip. necessary to do a detailed diagnosis and repair.
