Help with p0449 & p0455 codes
This is true. There is a possibility the hose connectors are loose/leaking. I was told that there as a way to do a vapor test to identify leaks. The hose connectors are tricky if you aren't used to working with them. You have to squeeze the sides of the connector in order to detach the hoses from the EVAP canister vent valve. I would start with the hoses that lead the the gas tank filler neck and check the connections. However, if you STILL receive an error code, test the EVAP canister vent valve solenoid to see if it is serviceable. I also recommend talking to a parts salesman in a Chevy dealership and find out if the part (which is only $32) is replaced on a regular basis (they will probably say "yes").
Maybe you could explain why this problem is not covered by the emissions warranty.
I just returned from the dealer with a 0449 code and the service person was explaining that the evap vent valve had to be replaced along with a rerouting of the tubing because its location as built in the factory proved to cause the problem. Being disappointed with his answers and confusing classification of the problem, perhaps you can enlighten GM customers as to why we have to pay to have an engineering mistake remedied, or at the very least, why a dealer would not fix the problem under the emissions warranty? I do believe fuel vapor recovery is an emissions prevention component. I could be wrong. Please advise
Thank you
I finally got to work on my wifes Tahoe. I looked for cracked hoses and didn't find any, so I went ahead and changed the vent solenoid I erased the code and my wife hasn't had any check eng light. If your wondering were it is located on a 08 Tahoe it is above the spare tire. You need to remove the spare tire to change it. When you buy the part from the dealer the solenoid comes with the hose that runs from the solenoid to the EVAP cansiter and the bracket. It cost about 32 bucks. Don't know how important this is but the EVAP canister is square and it is located toward the back of the gas tank to the right of it. Thanks for everyones help hope this helps someone.
hfdff,
Thanks for the follow up, all to often someone gets the needed info on this forum but do not follow up to say if it worked or not, and thanks for the info on locations as that is another very useful piece of info that sometimes gets left out..
Glad to see the part fixed your problem. I have found that this forum is a very useful sight, especially when people provide images and direction on how to diagnose problems. I would recommend taking pics of your projects and posting them here. They can sometimes be better than manuals. Look forward to hearing from you...
Im having the same problem on my 2003 Avalanche except when my check engine light comes on I can remove my fuel cap and its under alot of pressure and my milage goes to crap. I havent had a chance to work on it yet and Im not real sure where its located.
2006 Silverado - getting ready to address these codes PO449, PO455. Or atleast attempt to fix them. I was told to replace the solenoid (GM part# 1920-7763) I will let you know how it goes. The part ran me 110 bucks. Hope i got the right info.
