Help with p0449 & p0455 codes
Old Nov 5, 2010 | 4:08 PM
  #31
perrykt7's Avatar
how to reset after replacing solenoid CVS valve? driven 100+ miles the past two days
Old Nov 5, 2010 | 11:01 PM
  #32
Welcome to the forum.
If you don't have a scanner, most auto parts stores will scan/reset for free. Especially if you buy your parts there.
Old Nov 20, 2010 | 2:50 PM
  #33
Roccodawg's Avatar
I replaced this part due to a P0449 code, although Chevy had relocated it considerably further than shown here on my 2005 Tahoe LT 5.3. At any rate, the engine light is still on.....do I have to go get the code cleared or will it eventually clear on its own with some driving time if this were indeed the fix? Hoping I don't have to replace the solonoid or something else.
Old Nov 21, 2010 | 10:41 AM
  #34
Fat Strat Mann's Avatar
I finally got around to ordering the EVAP canister vent valve today. I'll pop back in here after the install and code clearing to report on whether or not it is fixed.
gmpartsdirect.com shipped for $27.67.
Old Nov 22, 2010 | 8:05 AM
  #35
Roccodawg's Avatar
Originally Posted by marine02xx@yahoo.com
HFDFF,
IT IS NOT THE GAS CAP!!! You will replace gas caps until your hair turns gray. I was receiving the P0449 code on my 2005 Chevy Tahoe LS, replaced two gas caps and still had the code. If you have replaced it once, P0449 come means there is issue with the EVAP canister vent valve located near the EVAP canister and the fuel tank. Do not get this confused with the EVAP purge valve located on the intake manifold. I ATTACHED INSTRUCTIONS that covers Tahoes/Yukons/Escalades/Silveradoes/1500s from the mid 2000s and a PICTURE of the actual EVAP canister vent valve that I replaced!!! This fixed my problem and it only costs $32.00 for the part FROM THE DEALER and 10 minutes!!!fficeffice" /><O></O>
<O> </O>
P0449 is an indicator that you have a slow leak in your EVAP system or the solenoid on the EVAP canister vent valve is not receiving the proper voltage. Yes, the gas cap can be the possible reason you have a small leak in your EVAP system, but if it continues after it is replaced, it’s the EVAP canister vent valve. I read a post where someone claimed that the dealer actually dropped the tank to replace it. That’s bull!! There is plenty of room to access this part. Please let me know if this helped.<O></O>
<O> </O>
marine02xx<O></O>
Bingo! Awesome post. Although my Evap canister vent valve had been relocted on my model for some reason, I traced it over right front of the spare tire area, changed it out, and the code cleared itself after about 5 miles of driving down the road. I just saved myself over $300 thanks to the helpful post. Cheers!
Old Feb 5, 2011 | 8:52 AM
  #36
TWL8apex's Avatar
I agree GREAT POST!! My wife's 2009 Suburban threw these codes about 5000 miles after warranty ran out. Had local Advance Auto reset once but they keep coming back. Will replace EVAP Canister this week and see if that does it.
GREAT info in this post!!!!
Old Feb 5, 2011 | 9:38 AM
  #37
burbancommander's Avatar
BE CAREFUL WITH THE VENT VALVE!!!!! you need to push in while twisting it counterclockwise to remove it. and then to put the new one in you need to push in on the new valve pretty hard and twist it clockwise. I broke two of these a couple days ago.
Old Apr 1, 2011 | 12:54 PM
  #38
jdbz71's Avatar
Originally Posted by brn2ryd
One side note: After purchasing the solenoid from the dealer I found out that the $110.00 TRUCK solenoid can be replaced by a cavelier or cobalt solenoid because they cross over or something. The CAR solenoid sells for around $40.00. I didn't check into this fully so...you may want to if you can save some coin. Pictures in link: Picasa Web Albums - brandon crawford - Truck
This is exactly what I need. Same part number, heater hose, etc. I appreciate your write up! One follow up to your comment about the use of the Cobalt or Cavalier solenoid. They are two different shapes that aren't an exact fit. They may be funtionally interchangeable, but it would take some fitting. The price is considerably different. Dealer price in Houston is $150 for the truck solenoid, and the Cobalt is about $40. GMpartsdirect.com has the truck solenoid for $78 bucks. Good stuff! Thanks!
Old Apr 1, 2011 | 1:07 PM
  #39
Thanks for the additional info update.
Old May 20, 2011 | 5:16 PM
  #40
Lostbowl's Avatar
Default po449 po455
Originally Posted by Chevrolet Customer Service
Well it looks like you've gotten a good amount of feed back from the great community here. If you've got any other kinds of issues such as warranty work, don't be afraid to reach out to me here.
Jeff Morris, Chevrolet Customer Service
Why does my owners manual say that emission control parts are covered for 80K. I have argued with my dealer and a GM rep. so I may as well post here. I have a 07 Tahoe that we drove to AZ in Dec. 2010 and on the way home with 34K on the clock I got the old loose gas cap (was not) followed by the check engine light. Since I deducted that it was an EVAP issue I decided to wait until we arrived home and take it to the dealer we bought it from. After returning we had accumulated 37,636 mi on the clock and the dealer replaced (according to their invoice) EVAP solenoid valve and charged me $146.80. What's going on here ? Now 31/2 mos. later I am getting the PO455 and GMs rep said it is not covered. This is not that big of an issue to loose a customer over. I am looking forward to your explanation.
regards, Thomas J. Jachim
906-884-4692
PS I offered the exact same info to the dealer, Parsons' of Eagle River
