Help with p0449 & p0455 codes
Old May 21, 2011 | 7:20 PM
  #41
Caddy Eskie's Avatar
I have a 02 escalade and my code says (small) evap leak do u think i should replace my evap canister vent valve??
Old May 21, 2011 | 7:33 PM
  #42
I have a 02 escalade and it reads "small evap leak" do u think i need to replace my evap canister vent valve as well cause i already replaced the purge valve
Old May 21, 2011 | 8:55 PM
  #43
Welcome to the forum.
Might do the gas cap first.
Old May 22, 2011 | 8:03 PM
  #44
Clean and check the seal of the gas cap and the filler neck where the cap seats... a very light coating of silicone lubricant on the gas cap seal might be worth a try....
If you replace the gas cap go with an OEM rather then an after-market, AC/Delco parts are going to have a level of quality control that the after-market may not..
Old May 23, 2011 | 8:28 AM
  #45
Official GM Rep
Originally Posted by Lostbowl
Why does my owners manual say that emission control parts are covered for 80K. I have argued with my dealer and a GM rep. so I may as well post here. I have a 07 Tahoe that we drove to AZ in Dec. 2010 and on the way home with 34K on the clock I got the old loose gas cap (was not) followed by the check engine light. Since I deducted that it was an EVAP issue I decided to wait until we arrived home and take it to the dealer we bought it from. After returning we had accumulated 37,636 mi on the clock and the dealer replaced (according to their invoice) EVAP solenoid valve and charged me $146.80. What's going on here ? Now 31/2 mos. later I am getting the PO455 and GMs rep said it is not covered. This is not that big of an issue to loose a customer over. I am looking forward to your explanation.
regards, Thomas J. Jachim
906-884-4692
PS I offered the exact same info to the dealer, Parsons' of Eagle River
Lostbowl,
I would like to look into this for you. I will need you to send me your VIN and your current mileage to take a look.
Thank you!
Elizabeth, Chevrolet Customer Service
Old May 25, 2011 | 11:08 AM
  #46
marine02xx@yahoo.com's Avatar
Lostbowl,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I hope you're able to identify the problem. Every time I read these posts, I see people recommending replacing the gas cap and even putting sealant on the gas cap seal. I've even read people suggesting buying a gas cap from the dealer instead of an aftermarket parts retailer, like the GM caps made in China are better that the other aftermarket brands made in China!!!. First, research the manufacturer of dealer and aftermarket gas caps and you will find there is no real difference in the "QC" process of the gas cap. PLEASE TEST THE VENT VALVE SOLENOID BEFORE YOU WASTE TIME!!! If the vent valve malfunctions, it will also throw a code. Please see the link below before you waste time replacing numerous gas caps. That's the amateur solution. Testing components and actually diagnosing the problem will save you money and heartache!<o></o>
https://chevroletforum.com/forum/tahoe-suburban-25/help-p0449-p0455-codes-32465/page3/<o></o>
<o></o>
Old May 25, 2011 | 11:17 AM
  #47
Yes. It is a dealer part only.
Old May 25, 2011 | 11:19 AM
  #48
Originally Posted by jmbead
I had code po449 on my 2006 avalanche can't find any craked or broken hoses. Is this a dealer part only
Yes, it is a dealer part, but inexpensive (approx. $40).
Old May 27, 2011 | 11:13 AM
  #49
I Replaced The, Canister Purge Solenoid Valve, & Evaporator Emission Canister Vent Solenoid Valve . And This Dum Code Still Pops Up!!! My next move is the gas cap and if this dum code still pops up then ima have to take it to the shop to get a SMOKE TEST done!!! Mor Money More Money !!!
Old Jun 21, 2011 | 1:49 AM
  #50
Goose33's Avatar
New guy here working on a friends truck with this problem haven't got to look at it yet but this has already been a lot of help and I have to give credit where credit is do! Thanks!
