Help with p0449 & p0455 codes
Old Apr 4, 2012 | 8:03 AM
  #141
Mike AAA Was the procedure you found similar to the one I posted above or was it different? The one I had said to relocate a bit higher and shield it near the fuel filler inlet...but as you did above the transmission will probably work also...
Old Apr 5, 2012 | 6:59 AM
  #142
Mike AAA's Avatar
I found the actual "Chevy Tech" procedure sheet and it suggested to put the vent up over the transmission housing facing downward so no dust would enter the sustem via gravity. I really found it major helpful! As I said, I'm a chimp but found this to be one of the easiest fixes I've done, short of changing a tire! Plus as one of the posters put it, "practicing taking the spare down in your garage or driveway is way safer than having to do it on the roadside" - valuable peice of info there for sure! I also failed to mention that use a short (maybe 2") section of the 5/8" heater hose to join the factory "hard" or "shiney" black hose with 2 hose clamps - you'll never get that hard plastic to slip over the new selenoid. Good luck - easy fix makes me look like a hero to the bride saving all that money plus just made me feel good doing it myself.
Old Apr 7, 2012 | 11:35 AM
  #143
cranker57's Avatar
Just thought I would tell you that I corrected the PO455 code. As I explained in my previous message, the mechanic changed the vent purge valve near the tank and another gas cap. Error still came up after a bout 1/2 hour of driving. Thanks to this site, I bought a canister purge valve that sits aon top of the engine held by one bolt. Cost $40 at the dealer and took 5 min. to put on, code is fixed ! Now I just have to find a spare tire winch / bracket to replace the rusted one that is on there, wont crank the cable in.
Old Apr 26, 2012 | 7:23 AM
  #144
back in the day's Avatar
I have read all the messages on this forum related to the P449 code. My wife's 05 Yukon XL is doing the same thing. I found the information informative and useful. I purchased the vent solenoid from Amazon of all places for 13.00. I put it on last night. So far, no service engine light. Thank you so much for the information. I guess it's time to try and tackle the service ride control light now....
Old May 11, 2012 | 3:58 PM
  #145
Chevy Family Man's Avatar
New User
Awaiting E-mail Confirmation
Hello Marine,
did you have issues putting gas in your tank ....gas keeps backing up and it takes for ever to fill. I have the same code you explained ....help
Tahoe Family Man
Old May 15, 2012 | 4:58 PM
  #146
Caridiot's Avatar
Hey family man,
I haven't had any error/check engine lights, but have had problems filling my 04 Suburban forever. It will click off every couple gallons then I have to pull, re-seat and start again, over and over... After reading and researching online I purchased a new vent valve from the dealer ($29.86) and installed today. Pretty easy install following directions posted on the forum which took 15-20 min. Checked the hoses while installing and they looked good, no visible cracks.
All this to say I drove to the gas station when finished and it still clicks off every couple gallons. Really frustrated. Anyone have any suggestions??
Car Idiot
Old Jun 18, 2012 | 12:32 PM
  #147
mdestefano3's Avatar
Default Had P0455 DTC
First, thanks to everyone here for an education on the EVAP system. I have an 07 Avalanche and I was able to locate everything and set up my list of things to go through prior to buying parts or enlisting the diagnostic help from the GM dealer. Before I started, I called to see if parts were available (of course they were, the parts guy knew the issue when I read him the part number- he certainly has seen this before).
I had the P0455 code. It was NOT the gas cap. However, I was lucky in that the fuel filler neck clamp was loose.
Once I tightened the clamp (for good measure I gave all of them a bit of a snug up), I turned the key and 5 seconds later the MIL went out. Took it for an inspection, which was a 20 minute ride, and everything passed.
So good advice on checking first, and for good measure, I checked the spare tire and greased it while I was underneath.
Old Jun 24, 2012 | 2:47 PM
  #148
Stew3000's Avatar
just wanted to say thanks for the post
this was my exact problem also.
EVAp canister vent valve - cost me 22.00 at KOI
thansk again
Stew3000
Old Jul 3, 2012 | 7:32 PM
  #149
luckychicago23's Avatar
Can someone help out please! My 2000 chevy Suburban Service engine light came on I got the codes p0453,p0446,p0452... I was driving my truck and it was bogging out when i returned to my house I opened my gas cap and Air started to rush out of it ( sounded like a punctured tire) the next day my truck would not stay running or hold any type of Idle, when I also tried to give it gas to see if that worked the truck would Die out instantly. A few days have passed and the Truck now will hold an Idle but when I give it gas I will not pass 3000rpm The Rpms will drop and the truck gives off a backfire! Im not sure if I should change the fule tank pressure censor, The evap purge vent or if its a fuel pump Issue! Any Ideas or help?
Old Jul 3, 2012 | 10:48 PM
  #150
Get your fuel pressure checked first.
Double posting unnecessary.
