Help with p0449 & p0455 codes
Old Jul 4, 2012 | 12:32 PM
  #151
luckychicago23's Avatar
Sorry Still new to this forum!! what should I do to check the pressure and after pressure is checked where should I go from there?
Old Jul 4, 2012 | 8:29 PM
  #152
You can either buy a fuel pressure test gauge or get someone to check it for you. That will tell you if the fuel pump is OK.
Old Jul 5, 2012 | 1:28 PM
  #153
The Fuel Pressure is ok! the fuel pump seems good, the Truck Drives and runs it just wont get past 30mph without stuttering and It just wont get the power. It's as like the truck has bad plugs but the plugs are brand new! Im currently changing the fuel Filter.
Old Jul 5, 2012 | 1:48 PM
  #154
Could be the throttle position sensor...
Old Jul 5, 2012 | 1:59 PM
  #155
kevinkpk's Avatar
The codes you previoiusly posted is consistant (also with back pressure in the gas tank) with evap purge valve problem. If those codes are cleared, try leaving the gas cap off for a test run. I'm thinking sticking purge valve evap canister
Old Jul 5, 2012 | 3:56 PM
  #156
JimJ's Avatar
What brand of plugs and what gap were they set at ?
Old Jul 5, 2012 | 4:04 PM
  #157
kevinkpk's Avatar
I ALWAYS at least spot check pre gapped plugs.
Old Jul 6, 2012 | 12:39 PM
  #158
The Gap is .40 and I used autolite.... just replaced the fuel Filter and still is doing the same thing.. Truck has a very good Idle not rough just when you rev up the engine like i said get up to 3000 rpm it backfires and looses power. I appreciate all the help you guys have been I think just to save time and the guessing game Im going to have to take it in!
Old Jul 6, 2012 | 1:10 PM
  #159
kevinkpk's Avatar
Are you still getting high pressure in the gas tank?
Old Jul 8, 2012 | 4:56 PM
  #160
Spot on, but ALWAYS check the plug gap pre-gaped or not... the plug could have been dropped at the factory or in the parts store...
