Old Jul 24, 2015, 4:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrian
Print Wikipost
HELP - Service Stabilitrak & Service Traction Control
Old Oct 10, 2015 | 8:16 PM
  #321
sshell's Avatar
Originally Posted by Dawn Stage
I have a 2007 Chevy Tahoe and I am having a similar issue with the Stabilitrak Off Traction Off Service message issue. My check engine light also comes on and reads a code of Cylinder 4 Misfire. It appears that there is a lot of this issue going on and no real good answer on how to fix it. Has anyone been able to fix it quickly?
I have a 2010 gmc the Stabilitrak and Traction off lights both are on along with my engine light. Was told misfire on cylinder 1 but replaced sparkplugs engine light off with no issues of missing or jurking all tho the other lights continue to stay on and can't figure out why.
Old Oct 26, 2015 | 11:26 AM
  #322
g007's Avatar
Welp, I took my Silverado to another dealer. I was told by the original dealer that the warranty I purchased was the 100k extended. And that's apparently not the case, it's only 12k/1yr. Awesome. I guess shame on me for not reading through it.
My Stabilitrack and traction control issue is the steering position sensor which is now not covered under any warranty and will end up costing me about $400.
The rest of the problems is low oil pressure. So far they've told me it was definitely low on oil. Last time I checked it a couple weeks ago, it looked full to me. Maybe I was reading it wrong. They want it back in a thousand miles to see where the oil is at. No leaks, so it's probably burning oil. They say it might be piston rings.
So I'll probably get through the winter with it and then get rid of it. I'm not going to be sinking a bunch of money into this thing. I will never ever go back to the original dealer. They do not want to spend any time whatsoever on simple diagnostics. After the second time telling them that it was running and shifting like crap and all I got was "no codes" each time, the only time I'd go back to that place is to punch someone in the face. I tell them the rear brakes definitely need to be adjusted and they can't even do that.
I am absolutely done with GM and will never buy another one. Good riddance Government Motors, I hope you die.
Old Oct 26, 2015 | 11:32 AM
  #323
Thanks for the update...
Old Oct 27, 2015 | 9:02 AM
  #324
gjseamanjr's Avatar
I fixed my Stabilitrak problem by replacing the terminal resistor (121 ohm) by rear crossmember and spare tire, and the brake switch. I also replaced the throttle body. On the oil problem it's probably the manifold filter located under the oil sensor. Cheap part about 5 bucks. Oil pump is simple and not the problem. Good luck -hope it works for you.
Old Oct 28, 2015 | 4:13 PM
  #325
early's Avatar
Newly Registered
Default Stabilitrak
gjseamanjr, Do you know the part # for the terminal resistor? And, a photo of its location?
thanks.
Old Nov 1, 2015 | 9:16 AM
  #326
Mountainman Streetbob's Avatar
Default 2012 suburban service stabilitrack service traction control
I was driving my 2012 suburban yesterday and went over some railroad tracks at about 35 mph, not a big jolt just a bump and my service stabilitrack service traction control indicators came on as well as the abs light. I checked for trouble codes with 2 different readers and i do not have any trouble codes. I checked for loose connections at both rear axle speed sensors as well as front hub speed sensors and maf and tb and fuses.... I can not find anything wrong.
Old Nov 2, 2015 | 4:09 PM
  #327
Welcome to the forum, you might need to physically disconnect, clean and reconnect each of the wheel speed sensors, they may have moisture in them or are making poor contact...
Also consider checking the rest of the harness for damage from debris
Old Nov 7, 2015 | 2:05 PM
  #328
DrSnook's Avatar
Patsy, I sent you a pm
Similar issue: Stabilitrak, hard shift, very rough idle etc.....sad so many with the same issues.
At the dealers now and after reading all these posts I am worried!!
Old Dec 14, 2015 | 1:19 PM
  #329
luvmytruck321's Avatar
Default Stabilitrak - Silverado 2007 LTZ
I had the stabilitrak light issue and resolved it by cleaning the mass air flow sensor. Yes that is correct, I had the light coming on while driving, then it would go off, then back on again. Annoying because it also prevented the remote start from working. So I went to AutoZone to have the codes checked (which resulted in about 12-15 different causes) and picked to least expensive choice, a $6 can of mass air flow sensor cleaner. Once I cleaned the flow sensor the light has remained off. BTW - the maintenance manual suggests that the sensor should be cleaned once a year. Good luck!
Old Jan 5, 2016 | 2:43 PM
  #330
jimena18's Avatar
Hello my name is jimena espinosa I have a Chevy Tahoe 2007... Its been about three weeks I've been having a lot of issues with my Tahoe it keeps popping up the stabilititrac words and its also reads that the engine is reducing power ... I've been in and out of the shop spend a lot of money trying to figure out what going on with my truck. But I've had no answer so far!! It has left me stranded in the middle of the street so many times Im afraid to even drive it anymore ... Because at times it runs good and just out of no where it starts doing it again... I need some guidance please!!! I've done some research and many of these year models have had the same issues with their trucks but so many different solutions... I really do not have the time or money to just try all of them if I take it to the agency its going to cost me a fortune to get it checked and fixed and I don't have the money for any of that!! I've been stranded with my 3 year old daughter in the back seat twice. I'm afraid to get in an accident due to this problem.. And the mechanics can't seem to find a solution for this
