Old Jul 24, 2015, 4:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrian
Print Wikipost
HELP - Service Stabilitrak & Service Traction Control
Old Jul 14, 2018 | 9:02 AM
  #441
peter36's Avatar
Default 2012 Chev Suburban Stabilitrak and Service Traction Control off and on?? Any Ideas?
Hello and HELP!
As stated my 2012 Suburban keeps flashing Service Traction Control and Service Stabiltrak, Control Other than that all appears normal It will come and go as I start and stop the vehicle, no other issues noted. Battery is new, about 6 months ago, Vehicle is in very good condition, 222000 KM, no other issues, can any one give me a starting point ?? Thank you Peter
Old Jul 15, 2018 | 8:34 AM
  #442
rldavid71's Avatar
Chris,
Do you have the 6.0 engine? If so, #1 is notorious for receiving less oil pressure due to some restriction. If you have determined that's where its at, like mine, I replaced the oil pump with a Melling high volume high pressure pump. if you have 4x4 its difficult. A shop will go by the book for cost to drop the front end, to lower the oil pan. I found some YouTube postings with another way and did it myself.
Hope you figure it out.
Robert
Old Sep 23, 2018 | 10:50 AM
  #443
Guvner2's Avatar
I posted this on another just started Stabilitrak post when I noticed this much longer thread. Didn't see any mention of what I learned here so figured I'd repost it. Apparently missing on certain cylinders will trigger a shut down of Stabilitrak, traction control and may generate the 0300 code along with the check engine light. Missing can be from a variety of things but it's now 2018 and one of the known problems has been the lifters involved in kicking down to 4 cylinders from 8. Obviously you don't think of misses being involved with brake systems or stabilitrak but the computer doesn't want a missing engine to cause other systems to fail. Anyway.. Here's everything I know at this point. (The misses are really hard to tell most of the time.) Scanner doesn't miss them though.
I just learned about this on a used Suburban I bought. A good thing for me is that I just decided a few months ago to buy a Snap ON Solus Edge scanner off of Ebay. What happens on the 5.3 engine is it has a system to kick down to 4 cylinders. This involved taking oil pressure away from certain lifters. 1, 4, 6 and 7. You need to get a good scanner and check the history of the misfires, easily done with the Solus Edge scanner. Mine had over 38,000 misfires on cylinder 4. Once reading that I changed the coil pack, spark plug wire and spark plug just to see the difference. Nothing changed. On this particular scanner you can turn to live feed and watch your engine while it runs for misfires. Mine kept it up running my misfire total up some more. What happens to the computer when it detects all these random misses is it shuts down the Stabilitrak and Traction Control giving you that nice error including the check engine light on your instrument cluster. No misses, no errors. You have misses you should eventually get the 0300 error code. There's a service bulletin out on this. 80-06-01-018B. They don't talk about the misses but I have a really tech savvy mechanic friend who knows all this by heart. Good luck..
Old Sep 24, 2018 | 7:25 AM
  #444
trainwreck91's Avatar
Well I got my suburban all figured out. After getting the service stablitrak and stuff. And multiple attempts at fixing it. I was getting a code for the tcc solenoid. So I replaced that. Have so drop the tranny pan to change it. As it is in the valve body. Worked for a day. Then came back. So I ended up replacing the entire internal transmission harness. Btw you have to splice the harness if you’re only doing the tcc solenoid. Thinking I made a bad connection I changed the entire harness. Worked for a day. Long story short. It turned out it was my tcm. The transmission control module was done. Got it off Maizin for around $80. Had a buddy of mine at Chevy reprogram it to the vehicles and voila. Has been good ever since. It’s been almost a year no issues. The tcm must be programmed using Chevy software. It is NOT plug and play. But very easy to change.
Old Sep 25, 2018 | 9:15 AM
  #445
Familyman5's Avatar
I have a 2008 suburban, started having some issues similar to you guys. Started out with an check engine light says "lost communication to primary fuel pump" but truck runs normal. Then abs, traction control and brake light came on. Service stability and brake system keep flashing. The brake light tends to go off and on and same with check engine light. Now the transmission seems to stop working with driving. We stop and turn the truck off and turn it back on and the transmission starts working again. I have ordered a "data link resistor" should be in tomorrow and going to start there. I will post results but wanted to see if anyone is having these issues as well?
Oh and now I have another code popping up - U2142 - lost communication with Yaw rate sensor.
Thanks,
bryan
Old Nov 14, 2018 | 11:26 AM
  #446
winger_bros's Avatar
New User
Awaiting E-mail Confirmation
Default Stabilitrak occurence and repair November 2018
good morning - 2007 Silverado LTZ crew 4x4 with 304,000 miles - owned since 168,000 miles - had almost five years. I have followed the forum on this issue for quite some time expecting problems. Surprisingly the first "major" item occurred yesterday. My daughter uses the truck for college. Some background - use Mobil 1 only, no AFM deactivate although I thought about it, done normal maintenance and found the truck to be very decent to work on. This truck does leak oil bad out the main rear and burns some; I do plan to fix the rear main next summer. We had used the truck to go to supper Monday night and worked normally. My daughter gets into the truck Tuesday morning and starts leaving the yard and all heck breaks loose - engine light flashes, stabilitrak icon flashes, truck stumbles and jerks. She made it to school OK - about 13 miles and calls to let me know. I go over and look at it at noon - yep it is a mess. I decide to leave work early and limp the thing home - I drove it and she drove the Ram. Got it home and the way it drove you would think it was toast. Ran diagnostic on the truck - here were the codes - PO175, PO301, PO301, PO172, PO175, PO300, CO561. I cleared and reread the codes - nothing there after clearing. I decide to pull #1 plug based upon the PO301 codes. The plug was bad - gunked up. I pulled all the plugs and the others were OK. I had replaced plugs at 245,000 - so they had about 60K on them. Go to O'Reily and bought the same AC plug and installed all 8. Fired it up and ran as normal. Went a couple miles and no problems. She drove it this morning and no issue. The fact that GM designs/codes the "action" of that condition, and has the truck act the way it did is a terrible design. The bad plug caused the misfire no question, but to go into a mode that causes the whole vehicle to be almost undriveable is incompetent. They should have triggered a low power situation, detune, etc. instead of making someone think the truck is on it's last leg. I have followed this forum over the years and this topic and wanted to share. The other big culprits are the throttle position senor and brake switch, although not exclusively. Also, the wonderful AFM is a problem too. Hope this info helps out someone else. I will follow up if anything else occurs. I may end up replacing the coil pak for #1 as well since the other plugs looked OK. It could be not firing as hot as need be - although I have had not previous engine lights or warnings.
Old Nov 15, 2018 | 9:15 AM
  #447
Guvner2's Avatar
One other thing I was told by several mechanic friends. First I bought a GM Goodwrench remanufactured motor from GM to replace my engine which had lifter and cam damage causing all my the lifters not pumping back up following a call by the energy management system to go back to 8 cylinders from 4. Secondly I got lucky I'm told as anytime the check engine light is flashing you're dumping fuel on the catalytic converter and may take it out. That's a bit pricey but not as much as it used to be. Good luck...
G..
Old Dec 11, 2018 | 10:22 AM
  #448
Welcome to the forum and thanks for the detailed analysis of your problem and your solution.
Old Dec 12, 2018 | 7:35 AM
  #449
New User
Update on the 2007 305,000 mile LTZ - working just fine since the incident in November 2018 I added to this string. A relief, but a clear indication of why people reach a huge frustration level with these vehicles and why GM hopefully has see some of these forums and been at least curious about this type of problem. I have some patience as this truck and our 2007 Suburban have been very good to us. The suburban is approaching 200K and we have had it about the same amount of time (purchasing is with 85K on it).
Old Dec 19, 2018 | 4:53 PM
  #450
jbuszkie's Avatar
Wow... Lots of folks with Stabitrack issue. I'll add mine in case there is some wisdom in where to start looking!
So my unique (or not so unique) situation... My traction control and stabiltrack light come on when it warms up. When it's cold (like it is now) the light goes
off and stays off until the car or ambient gets hotter. There is no loss of power or anything like that.
This seems like a loose connection somewhere!
Any thoughts?
Thanks,
Jim
