HID Head light installation instructions
Old Jan 21, 2009 | 11:41 PM
Tahoe fan's Avatar
Default HID Head light installation instructions
For those that have installed them, can you post a do it yourself? With pictures?
I bought my set but am having trouble installing them. The positive and negative wires going through the dust boot are killing me.
Any help would be much appreciated.
Old Jan 24, 2009 | 9:13 PM
EvansBlue's Avatar
Don't know if it will help you or not, but I made a how-to for the S10 and Blazer section.
https://chevroletforum.com/forum/s10-blazer-diy-useful-threads-62/how-hid-plug-play-install-drl-disable-13784/
Old Jan 26, 2009 | 1:27 PM
yarom's Avatar
Default Was not very hard at all
The ones I've installed over a year ago, were very easy.
Basically the ballast connects inline to your existing headlight harness. From the balast into the proper H11 HID bulb. The kit I got already had GM type connectors, so it was plug and play.
You need to secure the ballast units in the car with the provided holders. One went on the side wall (left side) and the other under the tray that is under the air intake.
Seems to be working so far. Nothing else was needed.
Make sure to buy a high quality kit as some of the cheaper ones go bad after a short while.
You also need to aim your headlights down a bit as the light is much stronger and the reflector is not made for this kind of light.
mightydog4805
Apr 14, 2020 12:11 PM
BMoTahoe
Sep 21, 2012 4:08 PM
DOBERDEWD
Dec 11, 2011 11:35 PM
OnDaGround
Oct 16, 2009 12:20 PM
MattWeed
Apr 30, 2008 11:17 AM
