How to Bleed the ABS?
Old Mar 1, 2009 | 8:03 PM
Leg0nd's Avatar
Default How to Bleed the ABS?
Hey guys! I am new to the forum, but am hoping that someone can tell me how to bleed the ABS brake system on my 2001 6.0 liter 3/4 ton suburban? Thanks!
Old Mar 1, 2009 | 9:29 PM
EvansBlue's Avatar
The same way you bleed a regular system.
Just loosen the bleeder screw and pump the brake until there's no bubbles. Refill the master cylinder after each bleed. Bleed in this order- LR,RR,LF,RF. Its a 2-man job.
Old Mar 2, 2009 | 3:24 PM
shawnvw's Avatar
Banned
Here is how GM explains it.....
Hydraulic Brake System Bleeding (Manual)
Caution: Refer to Brake Fluid Irritant Caution in the Preface section.
Notice: Refer to Brake Fluid Effects on Paint and Electrical Components Notice in the Preface section.
  1. [*]
Old Mar 5, 2009 | 4:29 PM
Leg0nd's Avatar
thanks guys! will work on it tonight!
Old Mar 5, 2009 | 8:02 PM
Leg0nd's Avatar
i got bled the brakes but the stupid light still came back on and the new abs pump won't stop howling. do you have to reset the pump? what else could be right? any suggestions?
Old Sep 27, 2013 | 1:24 AM
Russell Emmons's Avatar
Default replaced pads
hey i replaced the front pads opened the bleeder screws , bleed them brakes spongy theres no portioning valve to equalize or is that part of the abs?
barking spider
Sep 13, 2010 8:35 PM
heavychevy63
Aug 6, 2008 7:40 PM
Waltmoe
Aug 31, 2007 11:33 AM
chevy3quarta
Jul 27, 2007 5:19 PM
dogz46
Dec 9, 2006 8:34 PM
