ID of a part
Old May 14, 2016 | 6:13 PM
Hec's Avatar
Hec
Default ID of a part
Can someone ID part #3.
Old May 15, 2016 | 11:02 AM
cleveland63b's Avatar
what vehicle?
Old May 15, 2016 | 11:34 AM
Rednucleus's Avatar
Googled the diagram number and found it called motor kit brake pressure modue
2005 GMC Yukon SLE 2WD - TC0466102 Brake Lines/Front LM7MT1C15706
Old May 15, 2016 | 11:52 AM
Hec's Avatar
Hec
Sorry. 2006 Suburban LT 4X4
Old May 15, 2016 | 11:58 AM
Hec's Avatar
Hec
Thank you. I am hearing a vibration sound from the BPMV when accelerating at low speed. Had my left bearing along with the abs sensor done few weeks ago. Hearing the sound not all of the time but enough. Should I replace or live with the sound?
Old May 15, 2016 | 12:23 PM
Rednucleus's Avatar
In my 93, the motor cycles at 5mph when you 1st start driving - runs about 3 sec and stops - normal operation - no idea if you hear that in a '06
Old May 16, 2016 | 10:34 AM
Hec's Avatar
Hec
Yes in the 06, within 3 sec I am hearing the cycle. Not all the time do I hear this. Would a new part make this sound as well?
Old May 16, 2016 | 7:37 PM
probably nothing wrong with it, sounds like your abs is activating just from what you've typed
Old May 17, 2016 | 8:12 AM
Hec's Avatar
Hec
Thank you all for the info. Very helpful.
Old Feb 10, 2021 | 7:06 PM
Joshua Bova's Avatar
Default ID a part
Old thread, but hoping this will catch someone's eye. I am looking to for a part number, something I can order, for #24 in the diagram above - line from modulator to the connecting block. I've looked for this diagram elsewhere, can't find it anywhere - would be great to have the key for this.
-Josh
