Ignition fuse 99 Suburban
Old Aug 7, 2008 | 1:05 PM
deerhuntin1977's Avatar
Default Ignition fuse 99 Suburban
My ignition fuse keeps blowing every time I try to start my Suburban. Any ideas on what the problem might be?
Old Aug 14, 2008 | 9:01 AM
RonH's Avatar
Default RE: Ignition fuse 99 Suburban
Either the starter is pulling to much current or there is a short in the circuit somewhere. When does the fuse blow- when you turn the starter?
Old Jul 25, 2021 | 10:05 PM
staf4d's Avatar
I just encountered a stranded motorist with a 99 Chevy Suburban who had the exact same issue. For him it was a loose connection coming from a wire on the positive side of the battery to the firewall (junction) and then on to the fuse box. I fixed it by tightening the connection from the battery on one side then the other side from alternator and also two tiny bolts that connected it to firewall on the left and right. After nothing shook anymore it started and the fuse no longer blew. He had been stranded for hours before I came by. Hopefully this helps someone
raydar
Jan 20, 2023 10:46 PM
rubberpanman
21
Mar 12, 2021 1:11 PM
trund
Sep 18, 2020 9:25 AM
Titleistdrivr
Feb 23, 2020 3:23 PM
Tgoodrich3
Apr 26, 2012 11:04 AM
