Installed Rear Bumper Fascia/Hitch Cover, what do you think?
Old Jan 21, 2007 | 2:48 AM
  #31
engine2's Avatar
Default RE: Installed Rear Bumper Fascia/Hitch Cover, what do you think?
ORIGINAL: tahoe07
25U is the dark blue metallic
Thanks Tahoe07. Where does GM put the code on our trucks (its driving nuts because I spent 30 minutes looking for it in the dark a few hours ago and now I am challenged)
Old Jan 21, 2007 | 2:51 AM
  #32
tahoe07's Avatar
The REAL code is in the glove box. It is on the bottom line next to last code on mine, I believe.
I have a paint code list from the dealer. You know, one of those postcard sized cards with a line of color and the codes. Most of the time that will get you what you need. Some companies want the other code. I think it is817K for mine as opposed to the 63U that most call it.
Old Jan 21, 2007 | 2:57 AM
  #33
engine2's Avatar
ORIGINAL: tahoe07
The REAL code is in the glove box. It is on the bottom line, I believe.
Thanks, I glanced in there earlier tonight and figured it would have a notation about it being a paint code, but I am sure its in with the other 100 codes on the sticker.
Old Jan 21, 2007 | 3:15 AM
  #34
tahoe07's Avatar
Try this link to find possible numbers. The VERY BOTTOM number on my glove box list was the 817K found on this list should you need that code for something...link didn't work
Old Jan 21, 2007 | 12:54 PM
  #35
sjenkinzz's Avatar
Doesn't it slide to install and take off? If so, if you paint the seal, you could damage the paint on your bumper cover.
Old Jan 21, 2007 | 1:07 PM
  #36
biglg's Avatar
Yes, it does slide! I dont think I am going to paint it. I dont think painting the rubber seal would cause any damage. HOwever, when it slides it would be rubbing and may be almost impossible to keep paint on it! I am just going to leave it as is! Thanks!
Old Jan 21, 2007 | 1:27 PM
  #37
biglg's Avatar
Notice anything different from the first picture, compare to the 2nd and 3rd? Thanks tahoe07!
Old Jan 21, 2007 | 2:11 PM
  #38
tahoe07's Avatar
10X better!!
It just makes sense to do this if you are colormatching anything else-bowtie etc. While the paint is flowing...
Old Jan 21, 2007 | 2:15 PM
  #39
biglg's Avatar
I dont know if it is the amount of paint, or what. But the arm section with actual wiper doesnt seem to flex the same way it did. The wiper doesnt always touch 100 of the window. It seems there isnt enough pressure to now flex the blade onto the window. Have you watched yours while it is going?? Maybe it will get better over time. But this is my only issue with painting it. As for the looks, it looks great. However the function was affected. But I hardly use it and would take the look over the function of the rear wiper anyday!
Old Jan 21, 2007 | 2:26 PM
  #40
tahoe07's Avatar
Mine was not effected. I made sure to move it between coats like I said in the e-mail.
Let it dry forawhile then run it through its' range of motion. I also let mine dry in the sun for a few days before re-install. I put it inside the family room by thefrench doors and "baked" it for two days.
