Installed Rear Bumper Fascia/Hitch Cover, what do you think?
Old Jan 21, 2007 | 2:33 PM
  #41
biglg's Avatar
Default RE: Installed Rear Bumper Fascia/Hitch Cover, what do you think?
Maybe it will get better after time when it fully cures. I probably should have waited longer than 10 hours to install it! However, I get anxious!
It isnt the end pieces that dont flex. It is like the area where the end attaches to the big bar. The entire endsection! That area! I probably just need to let it dry a little and then go move it aroundnumerous times hopefully loosing it up.That or maybe some lube right on that area!To much friction (paint)in between the contact area! I dont really mind, I wont use it very often. But it doesnt function 100% effectively!
Old Jan 21, 2007 | 3:12 PM
  #42
davemec
Guest
Posts: n/a
ORIGINAL: biglg
mzfree is the user name. Here is my auction.
http://cgi.ebay.com/ebaymotors/ws/eB...112&rd=1,1
I noticed he had sold them. He lists them starting bid at 60 and buy it now at 70. I emailed him, he listed a white one for me and told me to bid the 60 and he would then end the auction to the current high bidder. Just tell him there is a guy/friend you know that just got a white one from him and tell him what you are looking for. He is a good seller, ships fast, and replies fast! Good luck and let me know if you have any other questions. Thanks.
Thanks for this info
Old Jan 21, 2007 | 3:54 PM
  #43
tahoe07's Avatar
I scraped the paint from the tabs that insert into the slots for that joint. I did tape it off but figured it would be easier to scrape it after than to get the perfect tape job. So I removed the tape and painted it all only to scrape the paint before re-assembly.
Maybe you can take it apart and remove some paint. Wait a little to let the paint cure first though.
Old Jan 21, 2007 | 3:56 PM
  #44
biglg's Avatar
Just tell them Landon sent you. He will take care of you!
Old Jan 21, 2007 | 3:58 PM
  #45
biglg's Avatar
I think that is what I need to do! That is the only joint that I have any problems with! By the way, you left that out of your "how to."
Old Jan 21, 2007 | 4:07 PM
  #46
tahoe07's Avatar
Gave you my number...TOO much info to get it all in writing. Sorry[sm=oopssign.gif]
Old Jan 21, 2007 | 6:12 PM
  #47
biglg's Avatar
No biggie! I actually took it off and trimmed the paint off the areas where it rubbed. You can actually see the spots where it rubs. I am going to now touch up a couple spots, then let it dry. I will leave it off longer this time! HOwever, I tried it after I removed the paint causing the rubbing and it worked perfectly. SO it will be fixed once I finally get it painted to my perfection. Just a couple very minor spots I wanted to touch up. So back to the drawing board! Will be done in a few hours! Thanks again for your help!
Old Jan 21, 2007 | 7:05 PM
  #48
#2 & #3 have a backup camera. Wiper looks good too.
Old Jan 23, 2007 | 3:11 AM
  #49
engine2's Avatar
ORIGINAL: biglg
Thanks Biglg, one is on the way to me.
DerekShiekhi
Aug 11, 2015 7:58 PM
Chevrolet Forum News
Oct 13, 2012 11:38 AM
samp215
Feb 25, 2009 6:17 PM
pete_dallas
Mar 2, 2008 11:16 PM
gassman
Aug 12, 2006 3:17 PM
