Key Power and parking light power - GMT900
Old Nov 3, 2010 | 4:42 PM
  #11
Amazon.com...
They have several versions if you search for Micro USB Auto Charger
EverWin Micro Sized USB Car Charger is the one I have
Belkin Micro USB Auto Charger is another very similar
Old Nov 3, 2010 | 10:53 PM
  #12
Originally Posted by SabrToothSqrl
I'm sure there are many scenarios that it would help, like my GPS that turns off when you take out the key... when jeeping I don't want it to turn off, because then I have to manually turn it back ON. I also don't want my CB to turn off just because I shut off the car... for pictures or lunch or whatever... so... Jeep and Ford give you a CHOICE... you have TWO outlets. One hot. One Keyed. It's the best of both worlds.
GM gives you no choice.
Has anyone tapped the parking lamps for anything?
I want 2 LED 'clearence' lights on the sides, on the vertical part of the running boards, I think it would look nice / neat...
Might check the fuse panel located at the end of the dash on the driver's side.
Old Nov 4, 2010 | 7:14 AM
  #13
SabrToothSqrl's Avatar
Default yes
while getting my probe on, the bottom left free pin has .5v with the key off and 12v with the key 'on'... so that one will work.
most of the power wires on this truck are hot all the time! no wonder the battery can't keep up...
Old Apr 3, 2011 | 10:46 PM
  #14
QUETRANPA's Avatar
as for the cigarette lighters always being hot I like it a lot!!! 'cause you can leave your cellphone charging, on the other hand I hate my wife's nissan I can't charge my phone in there 'cause the plug is only hot with the key, so is on and then I have to stop and is off, then back on the car again and is on again, that ruins your cellphone batt, so i will install a plug that will always be hot in her car.
and as for the acc wire in the newer trucks, yes there is a male pin in the junction box that is hot with the key, that is where I plugged my 12 cd changer and I don't have to worry when I exit the truck.
one thing I will do soon is I will plug to that male pin my 4 plug and it will be used for the radar detector and whatever needs to be on with the key, cooooooooolllll!!!!!!!
Old Mar 23, 2014 | 5:45 PM
  #15
Tony_V.'s Avatar
Originally Posted by in2pro
Well its not exactly what you were looking for but its a place to look...
I added a hidden 12v on at all times for my Garmin, I did it to remove the power cord from always being plugged in to the console outlets as it kinda ruins the looks.... Its hard to see the 12v outlet behind the support but it works well and I can conceal all the power cord all the way to the dash, where it comes out for the Navi...
Anyway you may want to check this panel for what you are looking for as the other available pins may be key powered....
Good idea. good information. I may use this for my Tahoe.
in2pro
16
Aug 10, 2022 12:36 PM
in2pro
Jun 24, 2014 9:57 PM
in2pro
Nov 7, 2012 3:46 PM
in2pro
12
Nov 15, 2010 11:40 PM
greysilver
Dec 30, 2008 10:40 PM
