LED interior and license plate lights
#31
Just another issue to this topic. Last week I have installed red led lamps for the tailgate breaklights. It worked fine, except... at night the cruise control was not working. After some readings over the Internet I found the responsible for this were the led lamps, so I replaced then with the original ones and the cruise control is working fine again.
Also, led lamps for the turn light signal is not good, as the turn lights start blinking very fast as if one of the lamps is dead.
Have a great day,
Sergio
Have a great day,
Sergio
#33
They had the resistors inside it, but it seems they don't have the proper resistance. Well, they are made in China, and unfortunately most of the things fabricated there do not have quality.
#34
The LED lights have resisters built in for the LED but that is not the same as the load resister(s) needed to fool the BCM... the BCM looks for low resistance and assumes its a bulb that is out...
A load resistor placed in line with the LED will create a higher resistance that a regular incandescent bulb would, the LED's will then flash correctly... however if the LED goes out the BCM will likely no longer know the lamp is out due to the resistor being in place...
Check out Super Bright LED's
Also look for LED's called Can Bus LED's these will have the resistors built in...
Woodna 1
November 13th, 2013 12:58 AM
MWRacing
February 14th, 2007 11:27 PM
ltzmego
September 26th, 2006 10:58 PM
