Lift gate stuck open in awful weather
Hello,
The lift gate on my 2016 Tahoe is stuck open and have tried everything and I can’t get it to close. The dealership is already closed for the evening and we are getting rain and snow tonight and tomorrow. Any ideas welcome!!!
Since your 2016 likely has push-button electrical opening, you'll need to try to remove the connector for the 3rd "arm" that actually raises and lowers the left gate. The pair of lift cartridges should hold up the lift gate so you can lower manually.
If manual open and close, support the lift gate about an inch higher than what it is now, like with a 2x4. Remove the two lift struts and then remove the 2x4 and lower the lift gate manually.
I'm going by what my 2014 has....
