Lift gate stuck open in awful weather
Old Dec 22, 2022 | 5:32 PM
CTtahoe343's Avatar
Default Lift gate stuck open in awful weather
Hello,
The lift gate on my 2016 Tahoe is stuck open and have tried everything and I can’t get it to close. The dealership is already closed for the evening and we are getting rain and snow tonight and tomorrow. Any ideas welcome!!!
Old Dec 23, 2022 | 9:04 AM
Cusser's Avatar
Originally Posted by CTtahoe343
Hello,
My guess:
Since your 2016 likely has push-button electrical opening, you'll need to try to remove the connector for the 3rd "arm" that actually raises and lowers the left gate. The pair of lift cartridges should hold up the lift gate so you can lower manually.
If manual open and close, support the lift gate about an inch higher than what it is now, like with a 2x4. Remove the two lift struts and then remove the 2x4 and lower the lift gate manually.
I'm going by what my 2014 has....
Old Dec 23, 2022 | 1:01 PM
intheburbs's Avatar
I'm a bit confused - I can still easily close my tailgate manually without the power assist. Are you saying the power-assist mechanism is physically jammed, preventing closure?
Old Dec 23, 2022 | 2:01 PM
Cusser's Avatar
ALL we know is what CTtahoe343 posted. We can guess he's in Connecticut, maybe not....
Old Dec 24, 2022 | 8:10 AM
repairman54's Avatar
Some owners do not know that they can manually close the tailgate.
Old Dec 24, 2022 | 9:32 AM
Cusser's Avatar
Some owners never open the owner's manual. You think Mrs. Cusser has????
Old Dec 24, 2022 | 9:34 AM
Cusser's Avatar
Sometimes disconnecting the negative cable from the battery for 15 minutes to re-set the vehicle computer can get weird stuff working again.
Old Dec 13, 2023 | 1:54 PM
MaxmantheTaxman's Avatar
THIS. This has absolutely worked for me with this same issue.
amaltez530
May 20, 2020 11:38 PM
kimmer1956
May 28, 2018 11:40 PM
Brucebadick
May 3, 2017 10:07 AM
Brucebadick
May 3, 2017 9:47 AM
starr-one
Mar 22, 2017 11:58 AM
