Last edit by: IB Advertising
- Chevrolet Silverado 1999-2006: How to Replace Oil Pressure Switch Sending Unit
Step by step instructions for do-it-yourself repairs.
Low Oil Pressure warning
Just test drove a 2009 Chevrolet Suburban with the 5.3 in it and 191,316 miles on it. It was very cold out -4 degrees F. After warming it up went for a drive, no unusual engine noise sounded good, on the way back the low engine oil light came on then went out. Stopped and checked the oil level it was good. Got back in and drove it back to the dealership and the light came on again and would not go out. Any suggestions on this?
Ok I am having the same problem with the low oil pressure warning light and check engine light coming on as others are. I have an 08 Suburban 1500 LTZ 6.0L 4 wheel drive with 112,000 miles. Never had this problem until now. Oil gauge started bouncing around then steadily began dropping eventually setting off warning. Stopped checked oil, it was full. Started back up pressure was back up. Drove it & within a few miles started dropping again. Took it to a friend who owns a shop and is an ASE certified master mechanic. He replaced the oil pressure sending unit. He said he wasn't charging me until we saw if that solved the problem. It worked for one day then the same thing. Well I had to take it to the dealer to get the door handle fixed so I had them check it out. They just called and said it was the oil pressure sending unit and was going to be $700 to fix. First I said I just had that replaced last week and second I said $700? The GM service guy said well we show that is what the problem is and the part alone is $600. Needless to say they are not fixing my vehicle. I called my mechanic friend and told him what the dealer said. He told me the OE GM part is only $86.24 and list 3.6 hrs labor. Thanks a lot Tyler Motors for trying to screw your customers, I bought this vehicle from you, I am going to trade it in for a Ford.
If you passed emissions recently (I assume you did), then your engine is running well.
Because of that I would guess you have something loose or something likely easy to replace about to fail.
air, fuel spark, sensors, wiring. it's won't be air since that would fail more regularly. fuel: a failed fuel pump usually acts up on cold starts. spark - a failed distributor coil would likely not start after stopping. failing sensor like crank or O2: possibly the cause and a cheap ODBII would tell you. wiring: a loose ground can shut off engine, yes, some grounds do that - most not - but some do - like the ground strap that hooks to a fuel tank.
If you don't have an OBDII reader w/trans, get one. They are cheap no excuse asking questions here if you haven't got one and read your status and codes.
