mysterious oil leak
Old Dec 25, 2013 | 12:02 PM
colguin's Avatar
Default mysterious oil leak
I have a 2003 Tahoe with just over a 100k on it. I noticed oil around the driver side valve cover and all over the surrounding area. I replaced both the valve cover gaskets and solved that problem. now I am noticing oil from underneath around the filter and oil pan area. Any ideas on where it might be coming from? I have heard and read it could be the oil pan gasket or the rear main seal but want to find out for sure before I go to replacing items.
Old Dec 25, 2013 | 12:15 PM
Welcome to the forum.
Best thing to do to determine the location of the leak is to clean the area thoroughly with some brake cleaner. Then recheck after some driving.
Old Dec 26, 2013 | 12:07 PM
I second the cleaning and checking, do make sure the filter is on snug... unless you are doing your own filter changes, you don't know how tight the technician that changed it put it on... it can be too tight, but it can also be loose, I'd make sure its at least hand tight...
You can check /tighten the oil pan bolts but don't over tighten them....
Tighten
Tighten the oil pan-to-block and oil pan-to-front cover bolts to 25 N·m (18 lb ft).
Tighten the oil pan-to-rear cover bolts to 12 N·m (106 lb in).
dstanely
Jul 3, 2014 8:19 PM
stop the rust
Jul 28, 2012 11:56 PM
dogmandan
Feb 8, 2012 8:51 PM
99er
Jul 12, 2011 1:51 AM
99ChevyZ71
Sep 2, 2010 7:05 AM
