Need to ask how to remove the lift gate inside panel to install rear camera...
Old Nov 25, 2008 | 8:17 AM
guvner's Avatar
Default Need to ask how to remove the lift gate inside panel to install rear camera...
I asked before but it probably got lost on the other things I was asking at the same time. Just want to know if anyone has pulled the inside panel off and what is the safe way to do it.
Thanks.. Gary
Old Nov 25, 2008 | 8:44 AM
genestoy's Avatar
Default RE: Need to ask how to remove the lift gate inside panel to install rear camera...
I did a complete "how to" some time back when I installed my Kenwood rear camera. Here is a link to the document with pics that I did at that time, hope that helps - http://home.earthlink.net/%7Egenesto...ra_install.doc
Old Nov 25, 2008 | 6:05 PM
d1nonly34's Avatar
sounds like a good write up. basically the lid is held in with clips. There are only two torx screws you need to remove and 2 push clips that you need to remove behind the glass. After that just tug and remove.
Old Jan 5, 2013 | 12:29 PM
Coheed's Avatar
i have a camera mounted near my hitch right now, and its not staying put and thinking of moving it...should be fairly easy to relocate the camera thanks for a great write up
Old Apr 7, 2014 | 10:02 AM
hurnik's Avatar
Does anyone have a copy of this write up they could email to me?
I'm in the same boat. 2005 Chevy Equinox LT and want to put a rear camera in the system.
Doesn't look like the original server link is active anymore. Here's hoping someone has a copy of it somewhere.
--Kevin
Old Apr 7, 2014 | 10:24 AM
Did you try an email to genestoy?
Old Apr 8, 2014 | 9:08 AM
hurnik's Avatar
PM or email? Profile says last login was a year ago.
But I'll try email route and hope they enabled the option.
--Kevin
RJK
Aug 2, 2019 5:50 PM
TomS209
Jul 23, 2015 12:22 PM
John789
Dec 7, 2010 3:05 PM
56brew
Apr 15, 2008 8:20 AM
dadztoy
Jan 28, 2008 1:54 PM
