Old Jul 22, 2015, 2:04 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
Need to change my CV
Old May 2, 2007 | 1:32 AM
  #11
Tommygunz's Avatar
Default RE: Need to change my CV
Even when the noise is only producable on one side of the differential?? I ill drain and examine soon....
Old May 7, 2007 | 9:48 AM
  #12
Tommygunz's Avatar
I dare to say the issue may be resolved. I chnged the differetial fluid with some Royal Purple Gear lube. There was evidence of very fine metal shavings. There was also some metal sludge stuck to the magnetic drain plug. I drained, filled with on quart and drained again to remove any particulate and refilled to spec with Royal Purple 75/90. All low speed indications are gone, no metal on metal, no tapping or clicking. I went to a large dirt parking lot and tried to get the front end to "groan" at speed as it used to and it would not do that. Then I took it out on the freeway an dwas doing up to 90 mph with no noticable vibration as there was befroe over 75 mph. While I beleive there was and still may be a small gear issue, having the correct weight and viscosity fluid in the case is definitely helping. I guess we'll see in a few thousand miles how often I have to change that fluid. If I get more buildup or not.
DeHartShadow
Mar 28, 2010 10:10 PM
owens87
Nov 27, 2007 1:23 AM
digdug
Feb 4, 2007 3:08 PM
kenandjenn
Dec 22, 2006 3:38 PM
