Need some help with 02 suburban tranny In Limp Mode
Old Jul 11, 2012 | 9:01 PM
ZAP's Avatar
ZAP
Default Need some help with 02 suburban tranny In Limp Mode
I'm working on a 02 suburban with a 4l60E that will go in and out of limp mode. The only code is P0756. I changed the B solenoid and the ignition switch so far without any luck. Need some help fellas on this so any input would be great! I do have a wiring ? That I need some input on, the mlps that is mounted on the driver side of the tranny has to 2 wiring plugs that plug into it. The one that has 6 total wires has a purple/white wire that I'm not getting ground nor voltage from the connector. Does anyone have any info on the wire? The issue is intermittent and can sometimes be corrected just by turning off the truck and back on.
Old Jul 11, 2012 | 9:53 PM
Tahoe0153's Avatar
Try replacing the speed sensor
Old Jul 11, 2012 | 10:48 PM
ZAP's Avatar
ZAP
Tahoe0153, Thanks for the reply. I will replace it and report back thanks.
Old Jul 13, 2012 | 11:28 PM
ZAP's Avatar
ZAP
Replaced VSS sensor and the problem still exist
Old Jul 16, 2012 | 10:26 AM
ebacon's Avatar
Try taking it to a qualified mechanic?
technicauto
Jan 23, 2017 10:15 AM
dirtracer19
Aug 18, 2015 2:45 PM
Kelly Timoffee
Dec 13, 2013 7:13 AM
cfreiling
Jun 29, 2012 10:32 AM
j460torino
Apr 5, 2011 6:27 PM
