New driver's side mirror has a mind of its own
Old Jan 15, 2010 | 11:27 PM
Buckhorn's Avatar
Default New driver's side mirror has a mind of its own
I have a 2004 Suburban Z71. Driver's side mirror was smashed by a passing truck after I parked on a narrow street (beware the streets in downtown Hamburg, PA!).
Since the mirror has the LED turn signal, puddle light, defrost and aiming motors, I figured it would be expensive to have a dealer replace it. I found a new replacement mirror online (innerauto.com, $196) and installed it myself.
The turn signal and puddle light work as expected. Mirror aiming, however, is totally out of control. When I unlock the car using the key fob, the mirror moves to the extreme down position. I can manually readjust it using the four-way button on the inside of the door, so the wiring seems okay. All attempts to set new positions using the programming button on the door fail -- the next time I unlock the car, the mirror moves back to the extreme down position. Any position I program it for is ignored.
I suspect this has something to do with some computer in the car. What's going on? What are my options for getting the mirror to behave properly again? Is this something I can correct myself? If so, how? Or will I have to take the car to a dealer?
Thanks for your help.
Old Jan 16, 2010 | 2:12 PM
Welcome to the forum.
Not sure but I'll bet you're right about it being the BCM.
Old Jan 17, 2010 | 9:33 AM
Buckhorn's Avatar
Thanks for the welcome.
I disconnected the battery for five minutes and grounded the cables for good measure, but that didn't solve the problem.
Old Nov 6, 2011 | 8:23 PM
kstough's Avatar
Exclamation Mine does the same thing--have you found a solution?
Have you found a solution to your problem? I am having the SAME problem!! I had to change out my motor and now the mirror moves to the extreme right...SOOOOO annoying.
05cavalier
May 20, 2015 1:42 AM
Bradc80
Sep 25, 2012 12:40 PM
98whitehoe
Mar 14, 2012 7:48 AM
kstough
Nov 18, 2011 9:38 AM
SWHouston
Jul 8, 2011 9:21 AM
