Off Road in Sand
Old Aug 22, 2010 | 6:29 PM
ldr's Avatar
ldr
Default Off Road in Sand
Hey there,
what would be the best setting for Sand Off Road conditions? StabiliTrak off? Shall I enable Tow/Haul Mode in order to generate more torque? Limit the gears from 1 to 3? Any experience on what works best?
Thanks
Lars
Old Aug 22, 2010 | 7:24 PM
Welcome to the forum,
All great questions, seems to me that the traction control enable/disable is a situation dependent, with it enabled it will limit the power to the wheels and that could be a good thing or a bad thing....off road I think I would keep the tow/haul enabled all the time as well as in 3rd for the added torque
Old Aug 23, 2010 | 12:30 AM
ldr's Avatar
ldr
Thought the same. Thanks
Old Aug 24, 2010 | 12:02 AM
Tow/Haul mode raises the shift points but not sure how it would increase torque.
Old Aug 24, 2010 | 1:01 AM
ldr's Avatar
ldr
Well you just answered it: By raising the shift points. Basically the car is longer in the high rev ranges which provide more torque as per the engine characteristics
Old Aug 24, 2010 | 2:56 PM
Also you get the torque multiplication from the torque converter.
Old Aug 24, 2010 | 10:57 PM
ldr's Avatar
ldr
Yes but only up to 1,000,000. After that you need to enable the flux compensator.
Old Aug 24, 2010 | 11:47 PM
And I thought it was a flux capacitor.
Old Aug 24, 2010 | 11:53 PM
ldr's Avatar
ldr
No that's what they call it in the DeLorean. At Chevrolet they call it compensator. It's a copyright thing I believe.
Old Aug 25, 2010 | 12:53 AM
o2bwln's Avatar
Remember to air down your tires. If you're running 32psi air it down to 10-15. Better traction and you won't be rooster tailing everywhere.
vwfye
Mar 3, 2014 11:48 AM
RubiRanch03
Jun 14, 2006 4:33 PM
