oil change question
Old Sep 9, 2013 | 2:24 PM
lspencer001's Avatar
Default oil change question
I have a 2003 suburban 2500 LT Autoride. the owners manual says to change the oil every 10,000 miles or once a year, whatever comes first. the oil life indicator has been saying 60% for several months now. I have never heard of changing the oil just once a year or the 10,000 miles. every car that I have owned in the past has always said to change the oil every 3,000 miles. should I wait till I reach the 10,000 mark or change it every 3,000 miles. thanks.
Old Sep 9, 2013 | 3:02 PM
Boy you are opening a can of worms for opinions...
If the vehicle is new to you, I would suggest having it changed now and have the monitor reset to ensure its working correctly....
I typically get mine changed in my 07 two times a year or about every 7-8k miles. I use the oil life monitor and M1
If you want to ignore the monitoring system I would say go with about every 4500... longer if you are using full synthetic.....
Old Sep 9, 2013 | 3:40 PM
Dave01's Avatar
I just did my first oil change on my 2010 Tahoe, just over 3,000 miles. But, so far I'm using conventional oil, will read more before deciding on what I will use for the long term. Even if synthetic I doubt I'd go beyond 5,000 given the potential oiling issues with the 5.3 MDS.
10,000 miles??? NO WAY!
Old Sep 9, 2013 | 4:11 PM
I do believe the literature that GM originally put out about the OLMS showed a potential of 12,000 before an oil change....and 10k is very do-able with synthetic and mostly highway miles as long as the level is kept in check...
Old Sep 9, 2013 | 4:14 PM
The powertrain warranty is based upon using conventional oil and oil life monitoring system. I go about 7K miles in a year and 0% on the OLMS. I do use Mobil 1 but would do the same w/ conventional oil.
Old Sep 9, 2013 | 4:24 PM
Dave01's Avatar
I should have added that since I have a GM certified vehicle with free oil changes, I'll be letting them put their conventional in unless I do the changes myself. After waiting over an hour for my "quick lube" I'm not so sure it's really free if my time is worth anything!
Old Sep 9, 2013 | 6:37 PM
ok thanks for the input. when I do the oil changes on my other vehicles I will change this oil and have the system reset and start fresh. didn't know there would be a big difference in responses.
Old Sep 9, 2013 | 7:40 PM
Here is the OLS propaganda
File Type: pdf
Old Sep 9, 2013 | 8:23 PM
thanks that helps a lot. looking at the chart it says that I should get about 7000 miles in between oil changes.
Old Oct 14, 2013 | 6:49 AM
1997Venture's Avatar
I've been doing once a year 10,000 mile AMSOIL synthetic oil and filter changes for the past 9 years on my 140,000 mile 2007 Venture and it runs great.
