Oil pressure switch
Old Mar 21, 2020 | 1:15 PM
daniel Patterson's Avatar
Default Oil pressure switch
I have a 2011 chevy suburban that had check engine light come on and when I took it to auto zone to check the code it came back as the oil pressure switch... the only thing is the gauge didnt show low oil didnt get hot. I check oil and it was reading fine.. but as I drove it and turn the corner the oil pressure light came on. What do I need to fix??? Could it be the whole motor?
Old Mar 21, 2020 | 1:38 PM
kevinkpk's Avatar
Could be the pressure transducer. I've had to replace one, but it was reading high, stuck on either pegged out, or 80. I don't know aht size engine you have, but the one I replaced on an 03 suburban 5.3L came with a screen that goes in underneath, you could have something like that plugged partially.
Old Mar 21, 2020 | 2:38 PM
if it was driving then why would you throw away the motor?
Low oil isn't the only cause for low pressure. It could be a failing pump, a blockage, or it could be a failing pressure sender too. You can test the sensor with a meter. I can't remember the proper ohm reading, but I'm sure google can tell you.
Old Mar 22, 2020 | 7:58 AM
I would first replace the pressure switch and change the oil and filter.
Old Mar 22, 2020 | 8:17 AM
...and replace the mesh screen under the oil pressure sender/switch.
banochris
Aug 22, 2018 2:21 PM
sekeraksm
Feb 3, 2011 3:07 PM
rtszolis
Feb 9, 2008 8:45 AM
walocke
Sep 17, 2007 5:40 PM
pissonadodge
May 7, 2007 10:02 AM
