Oil On Spark Plug Boot #1
Old Nov 13, 2023 | 1:29 PM
BigDMemfo60's Avatar
Default Oil On Spark Plug Boot #1
Hello,
I have a 2011 LTZ Surburban 4X4. Having an issue with oil acuminating on the boot of the #1 Spark Plug Boot. I thought it was coming from the valve cover gasket as it was the older type. I purchased the remade version and now it is tight and dry but the oil persists. I was originally alerted to the problem by a mis fire code. I am not having mis fires but still the oil is there after a good cleaning. Cover is dry. Can't seem to see where its coming from. Any ideas where to look on this model?
Many thanks!
Old Feb 18, 2025 | 10:12 PM
Default Again
Well it has happened again. Truck stumbling at idle and low and behold more oil on top of #1 plug that seeps into boot and fouls the plug causing mis fires. Any one have ANY IDEA? Valve cover tight, no leaks. Replaced with updated design. I have no idea..HELP?????
silverado2001
10
Dec 16, 2020 3:45 AM
Mikeypaul
Cruze
May 4, 2018 7:39 PM
wbywmu
1988 - 1998 (GMT400)
Oct 26, 2017 6:26 PM
Magnumglide
Jul 21, 2011 1:12 PM
peedeefish
Sonic (Aveo)
Jan 16, 2010 10:31 PM
