Outside air on passenger side
Old Nov 24, 2006 | 2:33 AM
sooner sled head's Avatar
Default Outside air on passenger side
Hopefully someone can help. I've got a 01 Suburban and each winter when traveling we can feel cold air come in from what appears to be under the dash on the passenger side of the vehicle. It's bad enough that we have to stuff a towel under the dash or have the passenger put a blanket over their feet. The rest of the vehicle is warm/comfortable but it causes problems for the passenger. I've searched the internet over and over and cannot find anything.
Does anyone have any ideas? The AC and heater are in normal working condition (I guess).
Old Nov 24, 2006 | 1:05 PM
usmc2037's Avatar
Default RE: Outside air on passenger side
On my 90 model there a duct or conduit leading to the front of the passenger compartment above the kick panel.May want to see if it has a hole in it. Appears to go to a vaccum advance device. Also want to check to see that the heater core case has been tightened to make sure air is not leaking through the firewall. Air bypass plate may be staying open a little letting air in after it has been swithed to heater. May need to have this adjusted, think there is an ajustment screw above heater core box behind the glove compartment. Check the wiring harness seal that connets the passenger compartment to the door(speaker wires, door electronics, etc..)to see if air is coming in there. Check the evaporator case(under hood) to make sure it is tighted properly so that air does not get by. AC lines going to evaporator case should have sealer stuffed into it to prevent air coming in.
Hope this helps, not an expert but these are the things I would look for first. Good Luck
Old Feb 24, 2008 | 7:24 PM
Bullet670's Avatar
ORIGINAL: sooner sled head
I have this exact same problem. I could not have explained it better! My wife is on my case to get it fixed(as she sits on that side)and the two dealerships I have taken it to do not know what it is. There are no TSB's. I was told that it was a common problem but I have not been able to find a fix yet.
Please help.
Old Feb 25, 2008 | 3:42 PM
shawnvw's Avatar
Banned
just recently my wife has been complaining about htis on our 02 trailblazer. I let her drive one day and could feel some very cold air from behind the glave box. I thikn it may be where the heater box bolts to the firewall. Probably the intake air seal is broken or has shrunk
Old Feb 25, 2008 | 6:47 PM
Bullet670's Avatar
I called in on one of those car fixing radio talk shows today and told them about this problem. They were astonished that the dealership did not know about this. He said that this is a problem on 2000-2004 Suburbans...ect... and all with that body. He said that basically someone forgot to seal a seam behind the dash. Most noticable in the norther climates. He said that it should be about $100 fix and take about an hour. The bad thing is that I was cut off before they could tell me how to do it myself. I don't want to have pay for this if someone could tell me what to look for and how to do it. Anyone had this fix done?
Old Feb 26, 2008 | 12:56 PM
Bullet670's Avatar
Well...I took it to yet another dealership today (3rd one) and I have an appointment to get it fixed tomorrow. He said...yes it is a common problem. He said that there is a seam behind the heater box that seperates. He said that it will take 1.5 hours and cost around $120-$130. GM even now makes a "kit" for it, so obvoiusly it is common problem.
I wanted to do this myself, but I cannot take it anymore from my wife. She does not even want to ride in it anymore and wants to take her car everywhere...which I hate to drive after driving a Suburban all the time.
I hope this information can help out someone else that has this same anoying problem! I will post if this does not pan out.
Old Feb 27, 2008 | 8:17 PM
shawnvw's Avatar
Banned
here's the bulletin......
#01-01-37-008: Passenger SIde of Vehicle Colder/Warmer Than Drivers SIde (Repair HVAC Case to Cowl Seal) - (Mar 29, 2001) [/align]
[/size]Subject:[/size]
Passenger Side of Vehicle Colder/Warmer Than Driver's Side (Repair HVAC Case to Cowl Seal)
[align=left]
Models:
1999-2001 Chevrolet and GMC C/K Pickup (Silverado, Sierra) and Utility (Suburban, Tahoe, Yukon, YukonXL) Models[/align][align=left]
2002 Cadillac Escalade[/align]
[hr]
Condition
Some customers may comment that the passenger side of the vehicle may be:
[ol]Colder than the driver's side when the heat mode is on.
Warmer than the driver's side when the air conditioning (A/C) mode is on.
There may be dampness on the vehicle dash assembly when the A/C mode is on. [/ol]
Cause
Condition may be due to poor sealing of the HVAC air inlet case to the front of dash or the recirculation mode door actuator may not hold the recirculation door closed while driving.
Correction
Replace the recirculation door actuator (if necessary) and repair the HVAC case to cowl seal using the following procedures:
[ol]Place the A/C control in the manual heat mode.
Remove the fixed mast radio antenna.
Open the hood and install fender covers.
Remove both wiper arm assemblies using the following procedure: [align=left]
4.1.
Disconnect the washer solvent hose from the air inlet grille panel nozzle.[/align][align=left]
4.2.
Remove the cover from the wiper arm retainer. Remove the retainer.[/align][align=left]
Important:Use a battery terminal puller in order to remove the wiper arm. [/align][/color]
[align=left]
4.2.
Rock the wiper arm back and forth in order to loosen the arm from the drive shaft. Remove the wiper arm.[/align]Lower the hood.
Remove the air inlet grille panel using the following procedure: [align=left]
6.1.
On each end of the air inlet grille panel is a rubber flap for the hood hinge cutout. Lift this flap and remove the air inlet grille panel attaching screw.[/align][align=left]
6.2.
Remove the air inlet grille panel center top push pin.[/align][align=left]
6.3.
Remove the clips that position the forward edge of the grille panel to the top of the cowl.[/align][align=left]
6.4.
Disconnect the windshield washer supply hose from the bottom of the grille panel.[/align][align=left]
6.5.
Remove the air inlet grille panel by sliding the panel rearward up the windshield and out.[/align]Just to the left of the right hood hinge, on the horizontal surface of the cowl, locate a cover that is sealed in place. The cover has TRW stamped into it.
With a sharp knife, cut out the panel following the panel impression in the sealer tape.
Place a lifting device between the cover and the dash. Lift the cover enough to allow another tool to depress and release the front retaining tabs by pushing rearward on them. Remove the cover.
Look through the opening where you just removed the cover. You will see what looks like a piece of foam about 76 x 127mm (3 x 5in). This is the A/C recirculation door that is within the HVAC module.
Reach into the opening and carefully pull on the air inlet recirculation door. If the recirculation door moves with very little effort, replace the air inlet (recirculation) door actuator (Manual systems only). For systems with the Automatic Temperature control, initialize the system using published Service procedures.
Between the top of the HVAC air inlet module (appears as a 6mm (1/4inch) black strip) and the cowl sheet metal is a foam seal. This foam seal may be improperly positioned or damaged in some way (insufficient crush/sealing). This may allow outside ambient air to enter the passenger compartment incorrectly (under driving conditions). This can be corrected using the following procedure:
[align=left]
Important:It is imperative that a good seal be achieved over the entire surface areas (no voids or skips), especially around the rear and sides of the HVAC case to cowl areas. [/align]
[align=left]
12.1.
Seal the area between the cowl and HVAC case with RTV Silicone Rubber Sealant, P/N12345739 (in Canada, use P/N10953541).[/align][align=left]
12.2.
Using your finger, from the engine side of the cowl, ensure that the foam is stuck nicely to the HVAC module and does not have any distortions.[/align][align=left]
12.3.
From the engine side of the cowl, working through the opening in the horizontal surface of the cowl, place a shop cloth into the opening and cover the blower fan. This keeps silicone from dripping onto the motor and causing an imbalance condition.[/align][align=left]
12.4.
From the engine side of the cowl, working through the opening in the horizontal surface of the cowl, apply the RTV silicone to bridge the gap and cover the foam between the cowl sheet metal and the HVAC module case. Inspect your work with a light and a mirror. Ensure that no gaps or skips are present in the RTV seal.[/align][align=left]
12.5.
Inspect your work for potential drips, runs, etc. If no problem is seen, remove the shop cloth covering the blower motor.[/align]Apply a 3mm (1/8in) bead of weatherstrip adhesive, P/N12345097 (in Canada, use P/N10953479) around the opening in the horizontal surface of the cowl, where the cover fits into the cowl.
Place the cover on the workbench, top on the surface, and apply a 3mm (1/8in) bead of weatherstrip adhesive on the edge of the cover.
Place the cover into the cowl opening and snap into place.
Apply another bead of weatherstrip adhesive around the joint between the cover and the top of the cowl. Smooth this bead into a smooth surface with a finger or tool of some kind.
Place the leaf screen to the cowl. Attach the washer supply hose to the bottom of the air inlet grille panel. Do not place the fasteners in at this time.
Install the radio fixed mast antenna. Tighten 1/4 turn after contact is made with the base.
Lower but do not close the hood.
Center the opening in the air inlet grille panel around the antenna mast and then install the air inlet grille panel retaining screws.
Tighten
Tighten the screws to 2N·m (18lbin).
Raise the hood.
Reinstall the air inlet grille panel center retainer and front edge retaining clips.
Cycle the wipers to ensure the wiper system is in the parked position.
[color=brown]Important:Inspect the windshield lower edge on each side. About 51-76mm (2-3in) from the bottom, you will find a 13mm (1/2in) long black mark embedded in the glass. The black line is the position for the wiper blade to be in when the wiper system is in the parked position.
Install the wiper arm assemblies. Position the wiper blades just below the black marks in the windshield.
Install the retaining nuts.
Tighten
Tighten the retainers to 25N·m (18lbft).
Reconnect the washer hoses.
Remove the fender covers.
Close the hood. [/ol]
Parts Information
Part Number
Description
12345097
(In Canada use P/N10953479)
Adhesive, Weatherstrip
12345739
(In Canada use P/N10953541)
Sealant, RTV Silicone
[/align]
Old Feb 27, 2008 | 8:36 PM
Bullet670's Avatar
Well....that is some great information! I hope that it helps others. After reading that I do not know if that would have been something I would have tackled. The dealership charged me $92 to fix it today for me. Well worth it to me.
alswann2009
Oct 23, 2022 12:52 PM
skategranger
Feb 18, 2013 2:38 PM
