programing instruction
Old Jul 30, 2007 | 7:06 PM
chief59's Avatar
Default programing instruction
I recently purchase a 98 tahoe, it only came with one keyleess entry remote. I bought a couple,with outprohgraming intrusctions but i caould not make them work. can any body send hepl with this? thanks
Old Jul 30, 2007 | 9:30 PM
tahoe07's Avatar
Default RE: programing instruction
Try this site
http://www.programyourremote.com/
Locate theData Link Port. It is locatedunder dash drivers side. Be sure you know which pins are8 and4.
(Notice port iswider on top row)
2. Make sure there are metal contact pins in terminals 8 and 4. Connect 8 to 4 with a suitable jumper wire (leave the jumper wire connected throughout the programming procedure). Make sure you know which terminals are 8 and 4. The vehicle will respond by locking and unlocking the doors to signify entering of programming mode.
3. Press and hold both the LOCK and UNLOCK buttons together on the first transmitter to be programmed. After about 15 seconds, the vehicle will respond by locking and unlocking the doors. Release the buttons on the transmitter.
4. Within one minute, repeat the previous step on the remaining transmitters to be programmed.
5. Remove jumper wire applied to the OBDII Port.
NoWalnuts
Nov 30, 2012 12:43 AM
mtyler7807
Feb 13, 2010 9:28 PM
gartz666
Dec 27, 2007 9:27 PM
redbaron
Aug 24, 2007 3:34 AM
