Rained here pretty hard and my 2007 Tahoe seems to have water in rear door.
Old Apr 17, 2012 | 12:43 AM
guvner's Avatar
Default Rained here pretty hard and my 2007 Tahoe seems to have water in rear door.
The door behind the driver seemed to have water sloshing around in it for half the day today before finally apparently draining out. Nothing seems to be missing to have allowed the water in but... The electric window has stopped. What's involved in fixing/checking the window?
Thanks...
Gary
Old Apr 17, 2012 | 8:41 AM
SabrToothSqrl's Avatar
Default well
first thing I would check is the fuse(s).
Old Apr 17, 2012 | 10:35 AM
Check the rubber wipers that run across the bottom of the window. Make sure it is not cracked or has part of it missing. You can try and fix the electric window, but if you don't fix the leak first, it will happen again.
Old Apr 17, 2012 | 10:47 AM
guvner's Avatar
Default Are there individual fuses for each window on each door?
The other doors all work fine.
Thanks... Gary
Old Apr 17, 2012 | 11:05 AM
Not sure about your year. Look at the fuse box covers, they are marked as to what each fuse is for. If the motor filled with water, it was damaged and might need to be replaced.
Old Apr 17, 2012 | 12:23 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> guvner,
If you have changed the fuse, it may be the motor (as oldchevy stated). You may want to have it inspected. If you need assistance with the fuses, please refer to page 557 of the owner's manual. For your convenience, a digital copy of the manual is available at: http://www.extendedgmwarranty.com/ow...olet-Tahoe.pdf
Louis
GM Customer Service
Old Apr 17, 2012 | 12:32 PM
Thumbs up not bad.
Props to Louis for posting something useful.
Don't forget the switch also likes to die.
Did you test the driver's door switch vs. the switch on that specific door?
Old Apr 17, 2012 | 2:57 PM
Camaro 69's Avatar
Site Ambassador
Believe it or else, the door to window seals aren't absolutely waterproof, that's why doors have drain holes on the bottom. Since you had water sloshing inside, your drain is obviously clogged with crud. Open the door, lay on the ground, look up at the underside of the door, and clean the drain holes/slots with a piece of wire or tiny screwdriver. Then run water down inside the door to give it a final flush out cycle if desired.
chevytrailblaz
Apr 9, 2021 10:07 PM
55mini
Nov 15, 2012 10:10 AM
Lili
Jan 4, 2011 10:55 AM
07kastenwagen
May 6, 2008 2:29 AM
Desertmami
Dec 26, 2007 7:49 PM
