Rainsense TSB
Old Feb 13, 2008 | 9:31 AM
davemec
Guest
Posts: n/a
Default Rainsense TSB
Does anyone know if there are any TSBs out for the Rainsense system? At times mine doesn't activate the wipers even though I have them on the highest sensitivity setting and the windshield is covered with rain. Then other times they seem to function just fine. Thought maybe there might be a software update from GM.
Old Feb 13, 2008 | 11:07 AM
GMz71's Avatar
Default RE: Rainsense TSB
I have had the same problem....i usually just turn them off then back on, and it seems to fix the problem.
Old Feb 13, 2008 | 3:40 PM
davemec
Guest
Posts: n/a
That usually helps me too, but I was hoping GM might have a software update to fix this issue.
Old Feb 13, 2008 | 8:45 PM
Not sure what GM did to make it a RainSense II but it doesn't seem to work as well as mine '02 TrailBlazer. Dealer said working as designed. []
Old Feb 13, 2008 | 9:00 PM
shawnvw's Avatar
Banned
The on;y bulletin out there is telling the techs that the sensor is separate from the lens on the windshield. Although there is a little tid bit of info that might help you......
If you do NOT find a fault in the system operation, please refer customers to Rainsense™ II Wipers in the Owner Manual for information for this system.[align=left]
If you do confirm a fault in the system operation, inspect the uniformity of the silicon gel linking the sensor to the windshield.[/align][align=left]
1.
If the silicon gel is distorted in any way or is not present at all, replace the lens only. Refer to Windshield Outside Moisture Sensor Lens Replacement in SI.[/align][align=left]
2.
If the gel is intact, replace the complete sensor assembly by referring to windshield outside moisture sensor replacement listed below.[/align][align=left][/align][align=left][/align][align=left]If you can see that the gel is distorted, it might give you some ammo when going into the dealer to get them to do something for you[/align]
Old Feb 14, 2008 | 7:53 AM
07summitwhite's Avatar
Yeah, same here. It defeats the purpose of having RainSense if you have to manlualy turn them on when it rains.
There made to word so your hands are on the wheel at all times and there not working right if you have to take one hand off the wheel to activate them.
Old Feb 14, 2008 | 9:37 AM
davemec
Guest
Posts: n/a
Thanks for the info, I'll take a look at the gel to see if anything looks funny.
Old Apr 1, 2008 | 2:04 PM
davemec
Guest
Posts: n/a
I had my Tahoe in today to have this looked at, and of course they say that everything is working fine and that the gel looks good too. They have a printout for me explaining that the variable levels of the rainsense controller makes it vary in the amount it runs. I'm glad the morons have this, cause I would have never been able to figure out that on my own even though I stated to them this morning when I dropped it off that I am using the highest variable setting and still it does not activate enough. I guess GM thinks that the people who buy their vehicles aren't smart enough to understand what variable wipers means.
Old Apr 21, 2008 | 4:43 PM
rockhardnupe7's Avatar
how do u activate the rainsense? and how do you adjust it?
Old Apr 21, 2008 | 9:48 PM
Just turn the **** from off to any of the delay positions and it is activated. The more you turn towards the low speed, the more sensitive it becomes. The next position is low speed then high speed. Turn the **** backwards from off and you can do one or more sweeps as it goes back to off when you let go. The Owner's Manual explains this.
