Rear Emblem for 2007 Tahoe
Old Sep 17, 2006 | 3:27 PM
  #21
Jefft0825's Avatar
Default RE: Rear Emblem for 2007 Tahoe
Does anyone know where I can find a black bowtie for the front and back?
Old Sep 27, 2006 | 4:47 PM
  #22
Slammed Birch's Avatar
Can someone definitively tell us whether there are holes under the rear badge? There are posts in this thread that seem to disagree on this point... Thanks!
Old Sep 28, 2006 | 12:30 AM
  #23
tahoe07's Avatar
I did this, so this is from experience not what I've heard. The rear emblem is two pieces. A large "chrome" emblem with a smaller plastic emblem in the cneter. The plastic emblem is clear with a gold foil stuck to the back. This outer emblem is held on by spots of glue/tape.
Take a small length of fishing line and work it in behind the outer plastic emblem. Use a sawing motion to "cut" throught the glue/tape as you work across the emblems. Most of mine was at the center of the outer bowtie. The outer emblem will pull right off once you get to the other side. Underneath you will reveal the under/larger emblem which does not have any holes in it.
If you remove the entire chrome and gold emblems as one unit --on the painted surface you will find holes.
[IMG]local://upfiles/3763/11C8328896404445B9F94A56F2FD0668.jpg[/IMG]
[IMG]local://upfiles/3763/715286F29096409C8DF41280AC9DCEB6.jpg[/IMG]
Old Sep 28, 2006 | 11:58 AM
  #24
davemec
Guest
Posts: n/a
I removed mine and there were no holes behind the outer gold emblem. Be carefull when removing it though, mine broke in half when I was trying to pry it from the glue.
Old Sep 28, 2006 | 1:32 PM
  #25
ORIGINAL: tahoe07
That is the info I was looking for. Thanks!
Old Sep 29, 2006 | 1:31 PM
  #26
Follow up question...
Has anyone pulled the gold insert off of the front bowtie? Can this be done to the same effect as the rear (which looks much better!)? Thanks.
Old Sep 29, 2006 | 8:15 PM
  #27
tahoe07's Avatar
No you can't. Once you remove the nuts from the back of the bowtie (from behind grille) the outer gold bowtie and black edge come off. They reveal a larger chrome outline with two large holes in the center where the posts went thru to the inside of the grille.
I tried this myself. No pics though.
Old Oct 2, 2006 | 8:02 PM
  #28
whatvrr's Avatar
Thank you Tractor77. We just pulled off the gold on the rear emblem and you are right it looks just like the front one we ordered from the dealership. It was so easy. I actually like it better than the front emblem because it's flatter.
Old Oct 3, 2006 | 12:16 AM
  #29
biglg's Avatar
Hi,
Does anyone have a front and rear silver/chrome bowtie emblem for the 07 tahoe they want to sell? Or either one. Thanks.
Old Oct 3, 2006 | 12:53 AM
  #30
DarkOne's Avatar
There is a replacement out there now. I have to find it again......but there is one. Ok go to www.stylinconcepts.com They have one there. Good luck
